Root [ROM] Ginger Fusion V1.0 [WIP]
azoller1
Android Expert
DISCLAIMER: NOT RESPONSIBLE IF YOU BRICK YOUR PHONE!!!!
THIS NEEDS TESTING!!!! WILL BOOT BUT NEED TO CHECK FOR ISSUES!!
rom is based off of stock and is modded for better overall performance!
this is part of my Fusion Series
Features
-Zipaligned
-Debloated
-Deodexed
-Rooted
-Added beats audio
-Added lightning zap tweak
-Init.d support
-stock kernel
-ES file manager
-Latest play store update
-Alarm clock xtreme free
-Rom toolbox free
-more to come.....
Downloads
V1.0beta- http://d-h.st/4MM TEST PLEASE!!
Installation
1. Download ROM
2. Reboot to recovery
3. Wipe Data if coming from stock or different ROM
4. Mount DATA and CACHE in mounts and storage
5. Install Zip
6. Wipe cache and dalvik after also fix permissions
7. reboot phone and let sit for a few minutes to let it work the tweaks
8. success
9. install any kernel you want after
Changelog
V1.0
-Initial Release
V1.3 Uploading
-added inverted play store, gmail and facebook and keyboard
-added more speed and batery tweaks
-gps tweaks
-use googles dns for faster internet and signals
-smoother
THANKS!!
http://forum.xda-developers.com/showthread.php?t=1802447 for tweak
http://forum.xda-developers.com/showthread.php?t=1525226 for beats audio
https://github.com/dsixda/Android-Kitchen/tags for the android kitchen
I wish I still had a Stratosphere to see this... I would highly suggest posting more info on this at RootzWiki (I copied this posting over there in it's entirety with proper credit!), it is kind of the de facto central hub for Stratosphere development. I started a thread here: [ROM] Ginger Fusion V1.0 [WIP] - Stratosphere - RootzWiki
One question people will quickly be asking: What firmware is this based on, EI2 or FF1? What kernel, radios, etc? Screen shots would be highly recommended as well...
I followed all directions and the phone will not detect wifi. I am running the stock ff1 kernel and flashed this rom to the system. everything else worked fine. any suggestions would be great.
This rom uses TweakStock 1.4 as a base, which is an EI2 rom. You need to use an EI2 kernel (custom or stock) in order for wifi to work.
will make an update with some more apps added or updated and some more tweaks for more speed and battery
u are one busy dude lol , love ur work on the spectrum . cant wait for 1.3 wold like to revive the old samsung as my back up phone , thanks
