GOV3.3 (Or Simply Glorious Overdose V 3.3)
GO v.3.3. changelog : LEAN-PERFORMANCE Build
This build is for power-users, people who want the most speed and performance out of their phone, with the best stability. You make sacrifices to stay up-to speed. Like a launcher change, or default apps for 3RD party ones.
Build.prop edits :
ro.HOME_APP_ADJ=1
(locks this in memory to speed up launcher access, since our launcher is small, this increases performance)
debug.sf.nootbootanimation=1 (slightly better battery, slightly faster boot)
dalvik.vm.dexopt-flags=m=v,o=y (better RAM and app management)
Stripped Browser.apk ---ADD YOUR OWN FROM PLAYSTORE!!!---
Stripped Maps.apk ---ADD IT FROM PLAYSTORE!!!---
Stripped anything to do with LiveWallpapers!
Stripped Memo.apk ---Download EverNote if you really need one!---
Stripped Street.apk ---Download from Playstore!!!---
Stripped Email.apk ---Either use GMail or 3rd party e-mail client!---
Stripped VoiceRecorder.apk ---What's the point?---
GO v 3.2 changelog : BULKY-ESSENTIALS Build
This build is for people who need it all, and need options at their fingertips. You're the type of user who looks to enjoy the scenery and aren't in a rush. You'll have apps of wide-arrays available at your fingertips for disposal. You won't have to make sacrifices, you have multiple launchers and keyboards.
*Kept MTM Gingerbread Keyboard
*Added ICS Keyboard.
*Kept LauncherPro
*Added Lightning Launcher.
*Added TouchWiz Calendar.
*Added TouchWiz Calculator.
** YOU HAVE MULTIPLE CHOICES BETWEEN KEYBOARDS AND LAUNCHERS! **
Tips for usage :
-- If you are experiencing a glitch while using the touch screen, simply pass a dry Q-Tip over the screen to remove excess grease and oil from your fingertips. Using a screen protector further remedies this situation. Disable the trackpad if you don't use for additional stability of the touchscreen.
-- Tegrak Overclock can be set to either further increase your battery performance, or increase your phone's speed.
Maximum STABLE performance (slightly lower battery life) - Set Tegrak Overclock to 1000 GHz MIN/MAX permforance govenor
Maximum STABLE battery (Significantly higher battery life, lower speed.) Set Tegrak Overclock to 100MHz - 400MHz conservative govenor
-- The default browser will be left for those who need it, but a recommended browser for this phone is Dolphin HD Mini.
-- Remember to SuperCharge with V6 Supercharger from zepplinrox. Simply set it to AGRESSIVE and bulletproof home launcher. Don't ask me how to do this, simply read the options and it should come to you.
-- If apps start to force close, immediately reboot into recovery, clear cache partition, dalvik cache, and fix permissions. This may happen due to installing new apps, using apps that require and access root permissions, or even uninstalling apps.
-- For most people, you won't even need to overclock. Due to the change of home screen launchers and it using a lot less RAM, lag isn't common. Only overclock if you require additional performance or if you are benchmarking your phone.
-- This particular ROM has fast dormancy activated. In a nutshell this means the following, when you are not in range of Wi-Fi, data (3G/4G) toggles on automatically. However, when in range of Wi-Fi, data will remain active, but not in use. (Thus you're connected everywhere you go instantly, but your battery remains intact.)
-- Disable GPS if you don't use Google Maps, Google Navigation, or Lookout Mobile Security. (save battery)
-- For additional battery, I do recommend using JuiceDefender. Although the battery life is pretty decent already.
I may add additional features, but this is what is planned for a near release. I'm waiting until I get my new rig back to do this. I'm not going to do this on a netbook running Linux, it's a pain in the ass as it is.
Mirror for BULKY-ESSENTIALS GO V 3.2
GOV32+BULKY-ESSENTIALS.zip
Mirror for LEAN-PERFORMANCE GO V 3.3
GOV33+LEAN-PERFORMANCE.zip
PLEASE NOTE! All credit goes to sduvick and ayoteddy and nxd without them NONE of this would be possible. I'm continuing their name in a legacy because this ROM implements their kernel, and theme amongst other things. Though nxd wasn't with PDT, he contributed a working fix in the kernel for the keyboard logging problem.
PLEASE LET ME KNOW OF ANY BUGS, so I CAN ATTEMPT TO FIX THEM!
CHECK YOUR MOUNTS, I CANNOT STRESS THIS ENOUGH!
Thanks to ayoteddy!
Looking for v6 supercharger? I recommend this one! : http://forum.xda-developers.com/attachment.php?attachmentid=661892&d=1311292674 -- Thanks Zepplinrox!
Build.prop edits :
ro.HOME_APP_ADJ=1
*Kept LauncherPro
Tips for usage :
Thanks to ayoteddy!
- Put zip file in your /sdcard
- Reboot into cwm recovery
- Wipe Data/Factory Reset
- Wipe Cache Partition
(Optional but recommended to prevent any minor issues)-Wipe Dalvik Cache from advanced menu in CWM
Quote:
*Now before you Flash, Only if you are on the orange CWM, (Not RED voodoo CWM from Bali) if on red CWM ignore the mounts/unmount part*
MAKE SURE YOUR MOUNTS LOOK LIKE THIS: (Go to mounts and storage from CWM recovery)
UNMOUNT CACHE
MOUNT DATA
MOUNT SDCARD
UNMOUNT SYSTEM - this is the ONLY mount you pay mind to, not Sdcard or anything else
- Now its safe to Flash the .zip
Quote:
(AGAIN IGNORE UNLESS IF YOU ARE ON A RED VOODOO RECOVERY) after you flash, go back to mounts and storage and make sure your mounts look like this
UNMOUNT CACHE
MOUNT DATA
UNMOUNT SDCARD
UNMOUNT SYSTEM
(Optional but recommended)-Wipe Cache then Wipe Dalvik Cache from advanced menu in CWM before Rebooting.
(To First Time installers, System Needs to be set to Unmount, though it would really be mounted. If you do Not do this you will have a softbrick and will have to ODIN to stock and start all over ....) Once you have Flashed a Custom ROM or Bali 2.2 Kernel you dont have to worry about mounts
