Root [Rom] Icarus Hd 1.8.3 Remix (aka Strippd) By SPJESTER, Jp1044 And T3T3Droid
SPJESTER
[font=helvetica, arial, sans-serif]Graphic by: [/font][font=arial, sans-serif]bhead9318, Edited by SPJESTER[/font]
[font=helvetica, arial, sans-serif]Team LiteSpeed's Website[/font]
[font=helvetica, arial, sans-serif]Icarus HD is based off of Motorola Blur .247 and had been debloated, deodexed, and optimized to the max.[/font]
[font=helvetica, arial, sans-serif]There are tons of features without compromise on performance or space. This ROM is the best of all worlds. [/font]
[font=helvetica, arial, sans-serif]You get performance, the best battery life, tons of features, and Motorola's next generation Blur all in one package.[/font]
Needs GAPPS: Nope
[font=helvetica, arial, sans-serif]Recovery to use: Safestrap 3.11 ONLY![/font]
[font=helvetica, arial, sans-serif]Prepare to be amazed at the amount of features this ROM includes:[/font]
[font=helvetica, arial, sans-serif]-Blur Camera that integrates with AOSP Gallery[/font]
[font=helvetica, arial, sans-serif]-OTA Update functionality[/font]
[font=helvetica, arial, sans-serif]-Extra Kernel Modules[/font]
[font=helvetica, arial, sans-serif]-Build.prop tweaks for performance and battery life[/font]
[font=helvetica, arial, sans-serif]-Init.d Tweaks[/font]
[font=helvetica, arial, sans-serif]-Ad-blocking app[/font]
[font=helvetica, arial, sans-serif]-Entitlement Check mod for VZW hotspot (tether for free!)[/font]
[font=helvetica, arial, sans-serif]-FM Radio[/font]
[font=helvetica, arial, sans-serif]-Notification Power Toggles[/font]
[font=helvetica, arial, sans-serif]-1% battery[/font]
[font=helvetica, arial, sans-serif]-Custom Boot Animation[/font]
[font=helvetica, arial, sans-serif]-CPU Sleeper[/font]
THIS IS A CONTINUATION OF THE OLD ROM, BUT TOTALLY REDONE, SO
IF YOU WOULD LIKE THE OLD ONE, GO TO THE OLD THREAD
Recently battery has been up and down and it just felt like it needed a reworking. So here it is
ICARUS HD 1.8 Remix (What use to be Stripped Edition)
-CREDITS:
JP1044
T3T3Droid
Rootuser94
sbreen94
It's a Combination of Icarus, With a Hint of Synergy
-Changed to OpenDNS DNS Service, (Only the DNS, Have not implemented the entire service)
(Only Dev to to that ^)
-Changed Wifi Scan to be less impactive
-Changed MaxWindows to 180
-Cleaned Up build.prop MASSIVELY (Should be better on battery)
-Updated Apps to Latest
-Removed Google Now
-Added SVoice
-Added OTA Support
-Added some of the Executioner's Ringtones
-Reverted to old Razr HD Bootanimation
-Colored Toggles
Changes for 1.8.3 (Current OTA and Full Version)
-Added File Support for Custom DNS (Browse more Secure)
-Added Exchange Service
-Added DNS Changer for Root
-Added Bluetooth File Transfer
-Added Rings Digital (Motorola Like Rings Widget)
-Old School Motorola Bootanimation
-Back to Old SMS App, Emoji one caused issues
-Updated Apps
(Up to Date as of 3/04) Apps Included
-AdAway
-Advanced Task Killer Free
-Bluetooth File Transfer
-Audio Manager
-Dropbox
-Flash Light
-GPS Status
-LTE On/Off
-Maps
-Mini Info
-No Frills CPU
-Nova Launcher
-OTA Updater
-Safestrap 3.11
-Terminal Emulator
[font=helvetica, arial, sans-serif]So now for the goods...[/font]
DOWNLOADS
V1.8.3 Remix
Direct Link: Dev-Host - Icarus HD 1.8.3 ReMiX FULL.zip - The Ultimate Free File Hosting / File Sharing Service
MD5Sum: 72e111f0326762143a9cd32ba935aad6
V1.8.3 Remix OTA (In case the OTA Updater Failed, Should say 4am Build time)
Direct Link: http://d-h.st/OFc
MD5Sum: 93e3f242ab833f2e6411f11b4b62309f
GOOD NEWS! OTA's NOW WORK! I CAN UPDATE YOU GUYS WITHOUT YOU KILLING THE ROM
MODS for 1.8.X:
(Stock SMS, No Emoji)
ICARUS-HD-1.8 STOCK SMS
HOW TO INSTALL OTA UPDATES:
[font=helvetica, arial, sans-serif]1. When you get the notification, tap 'Download'[/font]
[font=helvetica, arial, sans-serif]2. When't its done, select your wipes[/font]
[font=helvetica, arial, sans-serif]3. Then tap Install and wait for the update to install. Your phone will reboot normally after the update is finished.[/font]
[font=helvetica, arial, sans-serif]HOW TO INSTALL:[/font]
[font=helvetica, arial, sans-serif]1. Download ROM and put it on your SD Card[/font]
[font=helvetica, arial, sans-serif]2. Wipe data and cache in recovery of your choice[/font]
[font=helvetica, arial, sans-serif]3. Install the ROM and Reboot[/font]
[font=helvetica, arial, sans-serif]DONATION LINKS![/font]
[font=helvetica, arial, sans-serif]Like our work? Donation not required, but always appreciated [/font] :)
[font=helvetica, arial, sans-serif]T3T3droid: [/font]DONATE
[font=helvetica, arial, sans-serif]jp1044:[/font] DONATE
SPJESTER: DONATE
Looks good SPJESDTER. I have not flash a rom in awhile but I just might have to later. I will let you know what I think.
I have yet to jump into a custom ROM on my Bionic.
After running many different ones on my OG DrOID I wanted to give the stock system a chance (especially with ICS)
You are speaking my language however.
Stripped down, fast, debloated, everything I was looking for.
VERY tempting...
I did install the ROM.
Seems to run very well so far.
A few small, picky issues:
I do like colored icons on the toggles but the ones in the ROM right now just look horrible to me. It could be me just being spoiled, I was using Notification Toggle on stock and really liked some of their icon sets. Is that changeable? Is it possible to add or subtract items to the toggle list?
The GMail app thinks it wants to update with a new version from google but I keep getting a signature error when it does. Did you include a special version of GMail?
The included boot animation scared the s*** out of me the first time it booted. I though the phone had gone into a bootloop. Are regular boot animations, like even the stock one, compatible with the ROM?
I seem to be having not so good battery life today with the ROM but I do know a new ROM can take a couple days to settle in so I'll hold judgement there.
Umm the toggles are in the framework I do believe. Or system ui in the drawables folder. Edit whatever u want.... And boot animations work like any other ROM... My battery is doing fine I'm stock and got 16 hours yesterday an was still on 40%..
I'll look into those other items.
I have extended battery, from 8 am till now (6pm), mostly sitting at desk, went out for lunch, one phone call and about 60 texts. Battery is at 46%.
That's marginally worse than stock for me with roughly the same use.
But still, I'll give it a couple of days to acclimate.
Ok just a warning from here on out (this applies to all my threads), i wont be answering anymore "Why did you remove Google Now?" questions.
And my battery is fine (im on stock), maybe you should go to 3g mode or wifi when you can to save battery....
Well I gave it as long as I could.
For me, battery life actually declined after a week or so and just in the past couple days it began to drop data/4G/3G like they were poison.
It did that this morning and as a test, I booted my safe/stock system via safestrap and had no issues holding 4G in my office. Back to Icarus and it dropped after 30 seconds and I had no signal at all.
I do like the ROM, it is fast and clean but battery and signal are two biggies.
It could just be my phone doesn't like this specific ROM. I know my OGDroid would run stellar on some ROMs and like crap on others. No fault of the creators, it was just the phone.
Sorry, back to stock for me...
I've been trying to flash this ROM since last night. I'm on 4.2.2 and using SafeStrap 3.11. I've tried it on ROM-Slot 1 and 2. The flash seems to go fine with no errors. On the boot up however, I get the Motorola icon, then the SafeStrap screen, and then the phone resets. The softkeys black out and after a pause the Motorola screen comes up again (follow by Safestrap, etc). I'm wondering if there's something I'm missing. I'll list the steps I took in case someone is interested in lending advice.
1) Delete ROM-Slot-1 (was currently CM10.1)
2) Create a ROM slot in Slot 1 (1GB data partition)
3) Factory Reset Slot 1
4) Install IcarusHD 1.8.3 remix on Slot 1
5) Reboot system
I also tried the same steps with slot 2.
Thanks for looking.
