Root [ROM][JB4.2.1]CM10.1 Fusion V6.0 [2/3/2013][GOO.IM Updates][AROMA][KINGBEATZ]
azoller1
Android Expert
Jul 16, 2012
1,074
643
DISCLAIMER: I AM NOT RESPONSIBLE IF YOU MESS UP YOUR DEVICE JUST FOLLOW THE INSTRUCTIONS!!
Description
This Rom Is based off of CM10.1 Nightlies, But this rom is not a nightly rom, more of a weekly rom. I will just update this rom weekly or every few days with the latest nightlies or any other features i want to add, and this is meant for speed, stability, battery and great performance, plus good customization
Features
AROMA Installer
7 Kernels
-Franco
-M+/Metallice
-Raven Intersect
-LeanKernel
-Faux Kernel
-Trinity Kernel
-Omega Kernel
Stock CM10.1
Extras
-Tablet UI Mod
-TeamViewer App Quick Support
-PMR Tweak app
-Xperia Z Launcher
-Webcam Mod Here thanks!!
-PSM As Add-On
-Xenoamp as Add-On
Bootanimations
CM10.1 Fusion Custom Boot
AFAinHD first Boot
3D Nexus 7 Boot
Tron Boot (all made by AFAINHD)
Zero-G InkBoot Animation
MISC
Based off of CM10.1 1/16/2013 nightly
KingBeatz Audio Mod
PSN Suite Added (As option in aroma)
Init.d tweaks for speed and battery
build.prop tweaks
Other tweaks
Tapatalk HD beta app added (not in newsest version forgot to add it)
gps tweaked for better lock
Xperia Z Launcher
TeamViewer Quick app support
AFAINHD Bootanimation Custom Made For CM10.1 Fusion Rom's Thanks!!
Goo.im App/OTA Updates
Picasasync gallery app included (forgot to add in the newest version)
Clean
Smooth
The gapps has some inverted apps included (as and add-on now, not in aroma)
LaserDroid Tweaks and MPengine
Tweaked for great battery life
Bunch Of Options In Aroma
More to come....
Installation
1. Download ROM and GAPPS
2. Put it on your sdcard
3. Reboot to Recovery
4. Wipe Data, Cache, and Dalvik
4a. If Coming From Older CM 10.1 Fusion ROM Only Cache And Dalvik
5. Flash ROM
6. Flash Gapps
7. Reboot
8. Profit
Bug List:
-Dont flash tab ui mod!!! it will cause bootloop! but everything else works!
THANKS
A HUGE THANKS TO OMEGA KAOS FOR HELPING ME WITH AROMA!
Jamesst20 For getting tablet ui on cm10.1!
Everyone Here For The Amazing Kernels
To AFAINHD for the awesome bootanimations
Cyanogenmod for making cm possible for the nexus 7
Everyone at xda for making everything possible to get roms on the nexus 7!
Xda for the tweaks!
  • Like
Reactions: semus and colchiro
Here are some screenshots will post some more later and I have a theme installed called uber jelly right now
Upvote 0
So when I flash this will there be prompts asking me if there are certain elements I want to flash with this Rom? Well all this happen in recovery? Sorry I've never used arora so I don't know what to expect during the process.
Yes it will all happen during recovery it will ask you to select some stuff, and when it says DPI mod DONT select it, your tablet won't power up, I'm currently trying to fix it so don't check the box when it says DPI mod just click next
Upvote 0
BEST TECH IN 2023
Smartphones
