**ROM** ^^^^L I T H I U M mod v.1^^^^^
andriodadmirer
ANDROID ADMIRER HERE ...
Hey this is very little, but long overdue!
_________„„„„„^„„„„„__________
______________<<^^>>_____________
so what is this...
This is stock 2.3.4
&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;&#8226;
CHANGES
1.Changed default wallpaper
2.added custom. bootanimation that I made.
3. added dspmanager.apk
4.replaced launcher with huawei launcher
5.replaced stock camera and gallery with miui camera and gallery 6.installed BEATS AUDIO into system/bin
7. Completely. themed out using the Uot kitchen ( thanks uot!!!!!!)
8.V6 SUPERCHARGER AND 3g turbo charger installed
9. INIT.D SUPPORT
here are some screenshot
http://s1346.photobucket.com/albums/p683/Andriodadmirer
INSTALL INSTRUCTIONS
1.DOWNLOAD LITHIUM MOD
2. boot into cwm
3. backup your current rom
4. select factory/data reset
5. then wipe cache
6. go to mounts and storage
select to format...
a. cache
b. data
c. system
7. go to advanced, select wipe dalvic cache
8. go to install from sd
9. select the rom and then select yes to install
10. after it installs( may take a minute) choose reboot
_____________________________________
THIS ROM WILL TAKE A MINUTE ON FIRST BOOT AFTER MY BOOT ANIMATION GOES OFF THE SCREEN WILL BE BLANK ( BLACK) FOR A SEC
THEN WILL LOAD UP FINE
IF LAUNCHER SAYS IT FORCED CLOSED JUST SELECT OK AND IT WILL REOPEN FINE!!
My son has the ZTE score M (he is 12) So I didnt think I would root it or anything. I decided to root it as a christmas present for him if Link2sd will work as the phone sucks on storage space. How is your Rom on internal memory. I was suprised to see a Rom for this phone. Are there any bugs I should be concerned about? Thanks for the info. Also do you use link2sd on yours?
