Yes. I am planning to step into the world of custom Roms but am trying to approach it slowly and safely and the first step after Rooting is to set up a backup/restore system so I’ve got belt and braces firmly attached before I attempt a new Rom install and risk bricking my shiny new phone.
Regards
My phone is rooted I think. (At least when I go into Universal Androot – v1.6.1 and select Root it gives me a message saying ‘Your device is already rooted’
I then go into Rom Manager and select ‘Flash ClockworkMod Recovery’ (which says Current Recovery : ClockworkMod 5.0.2.0 Latest Recovery ClockworkMod 5.0.2.0)
I confirm phone model as ZTE Blade and something processes for maybe 40 seconds and I then get an error message ‘An error occurred while attempting to run privileged commands’
If I then attempt to Backup Current ROM I get the same error message.
Can anyone tell me what I am doing wrong or what to change to get round the error message?
Regards
Ok. I'll take the route you suggest. Thanks.
Regards
Hi there littler20......
Just a couple of points:
to permanently root your Blade/OSF, I would re3commend the special kallt_kaffe modified Blade version of Z4Root, which can be downloaded from Modaco, here.
Permanent root for 2.2 Blades! - Android @ MoDaCo
I assume you are on the original Orange 2.1 ROM, so the Z4Root above will work OK, and give you permanent Root privileges.
As you probably still on 2.1, and still Gen 1, ROM Manager latest Recovery(5.0.2.0) is only for Gen 2 Blades.
You can flash an appropriate Recovery from within ROM Manager, go for 3.0.1.4.
This can be done within ROM Manager by launching Rom Manager, selecting/tap All ClockworkMod Recoveries, at the bottom, and tap on 3.0.1.4.
This will give you an appropriate ClockworkMod Recovery for your Gen 1 device.
Not sure I would go with Recovery Manager, as it is not being updated, it was good at the beginning OK, when there was no support for the Blade, but ROM Manager is so now much more up to date, IMHO....
Recovery Manager was updated a couple of weeks ago.
Sebastian404 said:Ok, I'm not sure if anyone does care about this app anymore, but I've brought it back form the dead and updated it to work with 2.3 devices..
mostly inspired to get it working on my Skate...
Happy times
