Help Rom manager recovery problem
Hi! So I installed Rom Manager because apparently I need clockworkmod in order to get my voodoo lagfix working (2.3.3). But I can't seem to be able to boot into clockwork recovery =/.
First I installed rom manager and told it what phone I had. Then I pressed the "flash clockworkmod recovery" and it started to download something. Now if I use the manual recovery boot, it just goes into the stock recovery. And neither does the "reboot into recovery" from the app itself work.
Okay so apparently the flashing should've downloaded "update.zip" into my /sdcard and then using the stock recovery install (or whatever it does) it. But there is no update.zip in my phone.
I've tried to install it again but it did nothing.
I want to boot into cwm so I can apply my damn lagfix!
Any thoughts on how I should go on?
