inssane
Android Expert
I'm assuming RM has issues with running a backup. It doesn't initiate a backup once I am in CW recovery.
I can run the backup manually, but can't rename them (I like to name the ROM and date at least).
Once I go into RM and try to "manage backups" nothing shows up.
I saw that in CW recovery folder, in root explorer, the BU shows up in my sd-ext -- so I copied it to my sd - and it still doesn't show up in RM.
Any advice? Am I out of luck using RM as a whole?
I just want to label a few ROM backups and be able to access them readily without having to decipher the numbers that the backups are assigned.
Thanks
Thanks
