DB225
Camera has been working fine for me.
I got it working.
Its booting to the Lg screen where you set your account up but after the lg service waiver it goes right back to the original set up screen. I rebooted and still the same thing. Im not a noob and i followed the directions??
Any clues??
Any clues??
Not sure, most have got the rom installed and working. Maybe try the suggestion in post #16.
Or you can try to go into "twrp > mount > system" then "advanced > file manager > system > priv-app" and delete "LGCalculator, LGEmail, LGExchange, LGQuickMemo". Those apps are part of the LG EULA and by deleting them it might let you past the EULA setup screen. If you want those apps back go to "Settings > About phone > Update Center > App Updates".
That's pretty much all I can suggest.
i'll redo the steps again (i did followed the first time) but this time i'll go back to stock and reflash Katana
P.S. @GameTheory is OTG enable by default ? just wondering and if you are planning on OC feature
EDIT : Ok got it working with Tmo Variant ( yeyy ) just for those who want to try Katana make sure to flash T-mobile-Bootstack after flashing the Katana Rom if not will be getting some system Messages and your TWRP will not read your previews/current Backups and be a little messy don't know why that happen (i was worry about that 'till realize about you include the Metro Bootstack with the Katana )
I came from turbos debloat rom..
I twrp wiped the data etc. Flashed katana (thanks gametheory, I like how you changed those colors to "katana blue") then I flashed the bootstack I found on Android file host" then everything worked great. I'm on T-Mobile btw
Is there any way to add total support for layers manager or is that not possible for a stock based rom
Whats Bootstack?I came from turbos debloat rom..
That site is a bit finicky at times.The site you linked to has not loaded for me in the last two days.
I just gotta say GT, this isn't just a great new ROM(and you've added so much to it)...but even more, a great SERVICE-
Between this and the instructions, it's now totally illogical to remain on stock!
Before this there were so many ways to Bork... just looking for everything needed was so kludgy.
You've got my vote for AF MVP of 2015!
I appreciate your plethora of guides and projects.Thank you, I really appreciate that.
Hello. Great ROM. I haven't posted yet but I really appreciate all of your work. You've saved my but a few times already with this phone and my last phone (optimus f6). I also tried turbo's ROM on xda, but now I'm back to running Katana. I have a question though. I noticed that the stock email and quickmemo widgets don't work on any other launchers but the stock LG Launcher. I really like those widgets. Do you know of anyway to get the stock launcher back on my phone?
ROM updated rev_11-16-2015
Kernel Changes:
- GPU overclocked to 450 mhz (for improved gaming performance)
- CPU undervolt on lower frequencies (for saving battery when idle or screen off)
- Added HyperX governor and set to default (very fast)
- Added Conservative governor (for battery saving)
- Added SIO and FIOPS schedulers
- Lowered transition latency for Ondemand governor from 10mil to 9mil (for smoothness)
- Running kernel mode NEON
- -O2 optimized (might go -O3 on next update)
- New logger interface "/sys/kernel/logger_mode" (0 = disable & 1 = enabled) 0 is default. Ask on forum how to use.
- cflags optimizations (-mtune=cortex-a53 -mfpu=neon-vfpv4 -fgraphite -mfloat-abi=hard) and many more.
Enjoy folks.
LG Mail won't work if LG Exchange is not installed just fyi for those who wants the LG Mail
