Root [ROM] Mix2Fix (Modified Version of HawkEye ROM)
shahabazas
~*~ Android Addict ~*~
Mix2Fix ROM
Feature of Mix2Fix ROM
Original Dev Has Modded Everything On Mobile
Based On Android 2.3.5
Most Stable Rom You've Ever Experienced On Your A75
Fastest Gps Fixes
The only ROM having the most UNIQUE Lockscreen
Network icon and Notification panel are Modded by me using the UOT.
Volume Fix by me already included.
Custom Framework
Better Sensor Performance
Zipaligned
Best For Gamers
Proximity Sensor Tweaked
Better Internet Experience
Credits:
Yasirmujtaba of XDA The Original Dev of the ROM & drdogautam who ported it to Micromax A75
MEfor modifing n theaming it and also for adding few tweaks and scripts.
And to all the AFMMX MEMBERS as they have always inspired me and had helped me whenever i stuck in something. Buddies miss u a lot.
Special Thanks to krish1968 for uploading the ROM on 4shared.
Disclaimer/Warning:
I AM NOT RESPONSIBLE FOR ANY HARM DONE TO YOUR PHONE USING THIS . DONT BLAME ME IF YOUR PHONE TURNS INTO A PAPERWEIGHT/BRICKED USING THIS. DO IT ON YOUR OWN RISK.
How to flash well its the same way you flashed the other ROMs still wanna know ok
Installation:
1. Download the zips from Download link
2. Dump it to SD card
3. Reboot to recovery
4. Factory reset
5. Wipe cache
6. Go to Advanced
7. Wipe Dalvik Cache
8. Wipe Battery stats
9. Go back
10.Select install zip from SD card.
11.Select the ROM zip
12.Select Yes
13.After the flashing complete
14.Reboot
15.........ENJOY.......
First boot takes alittle bit time.
NOTE:As general rule BATTERY SHOULD BE CALIBRATED EVERY TIME WHENEVER YOU FLASH NEW ROM.So calibrate your battery properly.
ROM Download
Mix2Fix ROM Mega Download Link
Mix2Fix 4shared Download Link
ENJOY THE Mix2Fix ROM... Hope you all like it...
Screenshots:
Sorry I dint have any at this moment so you people can provide the screenshots once you finished flashing the ROM. I will update them in OP.
The Link to the Original Thread of the ROM Hawk Eye is Hawk Eye
Can Anybody upload this ROM on 4shared... Everwin, can u please?? I am trying to do some modifications in the silverlight ROM like changing the battery and network icons... Also i succeded in stopping the Auto sms Registration to the spice server that was charging us daily 1 to 2 Rs. But before that I want to taste this ROM too... that's y somebody please upload this ROM on 4shared....Please,,,,
How to download and in which folder it is downloaded? please tell i am enable to locate it.
Download it from Chrome browser as i am using the same so can let you know about it only the download starts and the progress is shown in the browser's open page and once the download gets completed you will get the zip downloaded and can find it in the download folder so untill the download gets completed dont close the page of Mega in which the progress is shown. Mega provides the fastest download you will notice it as i got the files like 400+mb downloaded in just 6mins and the files like 200+mb downloaded in just 3mins the upload has just taken only 5mins for me to get the ROM uploaded.
it's nice to see u all guys doing hard-work for this phone....downloading....will give feedback soon....great job shahabazas!!!!!
Will be waiting the reviews from you all guys and if some one has fast and unlimited internet then can upload it to some other site and provide me the link so that i can update it in OP and others like amolmendhe can get it downloaded it form there as i cant do it cos of restriction/blocking in the office.
Dear Shahabazas this rom dosnt have option to change ringtone/notification tone other than default nostalgia. how to add ringtone from sd card
Dera Sahabazas on ur request i uploded it to 4shared here is link
http://www.4shared.com/zip/vADswo1Gba/Mix2Fix.html
Buddy it has option to select ringtone/notification tone as i still have the phone and using the same ROM let me check once i reach home will check and confirm it till then you can select any ringtone from the music player or from the file manager to set as ringtone. By the way what about other things are they working fine and did you like the ROM as no one posted the review for it so can you atleast let me know is the ROM working properly.
Mix2Fix - Download - 4shared - k nandi
Thanks for the 4shared link the OP is updated with the 4shared link and your name has been added in the credit section.
Dear Sahabazas I lik the rom but proximity issue is there during call screen goes black. Awsome screen on of not working as it required to reduce power button utilization .I will update any other problem .As I back to stock based rom due to proximity issue. thanks for ur hard work
Yes proximity problem is there in this rom any solution....
How come you all are getting proximity issue as i am using the same ROM since from months but dint find any proximity issue. I will try to get some solution for it but i am confused as i am not getting any issue so how to check what is creating the problem still let me see what i can do.
I think base Rom of Hawk eye is Lenovo rom it is different than stock rom so sensor sensitivity might be different.
