[ROM][Nightly] Stormy Nights
Status
Not open for further replies.
j2cool2012
There will be no nighties for now until the next version of StormDroid is ready to begin testing.
Welcome to StormDroid Nightly. We are proud to announce that starting tomorrow, we will be producing a new build of StormDroid every day, much like CyanogenMod does now. We are hoping this will allow us to be able to gain more user feedback, and will allow us to expand our tester base, and release the next major version of Stormdroid bigger, badder, and stormier than ever before. You can find the changelog here, and report any bugs you find here. Leave comments in the section below as well.
StormDroid Nightlies
Please do not redistribute without permission from the StormDroid Team.​
Reporting Bugs
  • Please report bugs in the Google Doc located here.
  • Please do not report a bug that has already been reported.
  • The existing bug list is located here.
Submitting a Fix
  • If you found a bug, and know how to fix it, feel free to fix it.
  • Please test your fixes before submitting to the team.
  • Email the files to The StormDroid Team
When emailing a bug fix to us, provide the following information:
Name: (Android Forums Username)
Bug: (What was the bug?)
Fix: (How did you fix it?)
Still getting page not found for Change log and report bugs links in the first post of this thread..
Is it necessary to clear everything and start from scratch (clear cache and dalvic cache) if we want to load a newer version as in going from 10/13 to 10/16 nightly?
Dalvik2Cache is not working in 10-16, I will tinker with the source files after I wake up and try to get it working again. I also plan on adding some new tweaks to the ROM :D
Okay, some of you may think it's a dumb question, but I am sure someone could answer.
rcozzi, actually, unless noted in the nightly detaily, you are safe not wiping when updating between nightlies. Data, that is. always WIPE THE CACHE AND DALVIK.
Nightly 10/25
Replaced cm6 sms with GOsms
What is the general difference between the two?
Better question would be, Is there an issue with the existing sms that would create a need for the change?
Nightly 10/25
The sms we had before (cm6) could not send or recieve mms. We replaced it with GO sms pro hoping to fix that, but GO sms hangs on contact selection I hear. I'm working on a cm6 mms fix.
I tried manually removing cm6 and installing GOsms And it seems to be working with no glitch.
Thats odd. Maybe GOsms has a library that I forgot to install.
EDIT:
It does have library files. Ima make a new nightly with it installed properly.
Status
