Root [ROM] NIN-TerribleLie-DX-Alpha9 [ICS-DX-SomeSense-3.6][6-26-12]
Chingling
Notice: This is not my work. I have simply ported the ROM so that MMS is working with our Evo V's. All the credit for this ROM goes to NineInchNails over at XDA. I have received his permission to repost the ROM here. Go give him a bunch of thanks if you loved this.
NIN-TerribleLie Original Post
Alright, let's get down to business:
(OP mostly copied from XDA)
NineInchNails presents
TerribleLie-DX-SomeSense
This ROM is a blend of DX Home by Tapas mobile and Sense 3.6. THIS IS NOT MIUI. So please don't try and compare them. I did this to be different. Yes there's Chinese language in the ROM. But it's not completely unbearable. If given the time I just may translate everything but I feel what is in Chinese isn't essential for now. There's going to be a lot that may confuse you. Don't worry. Just READ before messing around with the options of everything or you just may end up downloading a Hello Kitty Theme (ahem.. diestarbucks ) Most of the issues you may encounter are DX issues that I can't resolve but I know of most of them and they do get reported to the developers of DX Home. Overall the Rom is stable and works.
The Goods:
All the basics work Thanks to dropzeroc's base
Camera 2D and 3D
Linux 3 Stock HTC Kernel
Calls
Data
WiFi
SMS
MMS
Web
Bluetooth
4G
Sense Lockscreen - No shortcuts but Music Widget works
Leedroid Tweaks - although obviously Rosie settings have no effect
Beats
Dolby SRS
Sense 4 clock widget apk - because DX clock and weather clocks suck.
Default homepage still links to dropzeroc's mikmik thread - its his base why not
Lowered MIN CPU to 384
Sense aspects still Odex for performance
Bugs:
Going to shortcuts and adding an app the icons are correct but the labels to them are wrong
Home button in App drawer does not return to homescreen - Reboot or applying a theme seems to fix this
Fade effect to App drawer which is set as default just looks weird. There is an option to change it to Lamp Effect. Pretty trippy
2 Battery Icons - DX battery icon (upper left) can be removed in DX Battery.
Not all Chinese language removed.
GPS toggle goes to GPS settings - Guess that's how they wanted it
Mobile toggle does not work - clicking it says No SIM card detected!! just remove it. Quick options has mobile toggle anyways
9016 notification after first boot
Probably more that I can't think of at this moment but nothing major
Best way when an update happens is to use the Play Store. They have options to check for updates and install them in the options but it seems to work better letting them install when the Play Store version of DX Home updates. Right now the update in the Play store will just change the Wallpaper due to me pushing my own to the apk. The version is still 3.1.0, The choice is yours. If you want my wallpaper back just ask and I'll post it.
Thanks to:
NineInchNails
dropzeroc - for the base - Major Thanks to him!!! ZR3DX-Sense 3.6 [team420]-THEMED-Sprint-BEATS-odex-EXTRAS
diestarbucks - Tester
dastin1015 - Tester
ch1naski - moral support and tester
il Duce - network tweaks from dropzeroc's and quickboot added to quicksettings
pstevep - for moral support and recommending me for RC
All of Team D3rp - the best bunch of people on XDA. Seriously.
ESCCODE - MSL app
Sirius - Quickboot app
Instructions:
If S-Off:
  • Wipe (Factory Reset and Caches)
  • Flash zip
  • Reboot and Enjoy
If S-On:
Flash zip in 4ext with Smart Flash on
Reboot and Enjoy
S-Off is recommended, but S-On works too. Hboot version does not matter.
Downloads:
NIN-DX-TerribleLie-Alpha9_VMshooter.zip
Thanks to il Duce for quickboot in quicksettings
added quickboot.apk and MSLReader.apk
Mild cleaning.
Anthrax Kernel is compatible with this ROM. For those who want to install Anthrax, sign up at the Anthrax Forums and download/flash the latest Anthrax Kernel
Anthrax Forums
Other Stuff :D
DX Battery Booster - Excellent Battery monitor and manager
DX Contacts - Handles Contacts, Messaging, and Dialer
TONS of customization - many of which I don't know about yet or have tried
Stable Android ICS Sense 3.6 VM base from dropzeroc
NIN ringtone included
More Thanks to my main tester diestarbucks and il Duce for letting me borrow him - this wouldn't have been possible without this guy dastin1015 and ch1naski encouraging me
MAJOR THANKS to dropzeroc for the base!
Thanks to Kfunk for the Awesome Splash IMG in post #2!!
Thanks to the Chinese Devs behind Tapas Mobile. All the old Hero CDMA buddies on here (too many of you to name ) and XDA. If it wasn't for XDA I wouldn't have ever gotten into Android as much as I have.
Alright, time for my Credits!
  • First off, NineInchNails, who created this wonderful ROM
  • krowley3 for making the MMS Port possible
  • jmz for making the Stock ROM accessable
This would not even be here if NineInchNails hadn't made it in the first place, so go give him a nice donation if you loved this ROM ;)
DONATE to NineInchNails
I love the look of it but is there CPU overclocking with this ROM? Or does anyone have a quad score for it?
Sorry to revive an old thread, but I can't seem to get this to download. Is there still an active one? Because I really like how this ROM looks.
Yeah, I didn't think it was once I saw it on XDA. Maybe I'll just hara...Politely ask Chingling either A) What had to be done or B) if they have another copy of the ROM.
