Root [ROM] port [ALPHA] Shendu OS
henslo
Welcome To Shendu!!
Today brings a Chinese developer of Android OS. Its name, Shendu OS. Hope you like.
It is built up based on CM7 for the Epic 4G and Shendu OS on the ZTE V880.
Security, Stability, Simplicity.
I NEED SOME DEVELOPERS ASSISTANCE ON THIS AS IT SEEMS TO BE A BIT DIFFICULT WITHOUT A DEVICE AND A LOGCAT WOULD BE GREATLY APPRECIATED PM YOUR EMAIL SO WE CAN GTALK AND GET THIS PUPPY AT A STABLE STATUS
Working:
3G : Turn on Data Roaming
WiFi
Phone
Sms
PC Mount
initial force close with com.phone. process still trying to find the issue
Wallpapers
Not Working:
4G
If anything else, you tell me.
ScreenShots:
CREDITS GO TO
*CM7 TEAM for the base credit to:g60madman
*BIGSPLIT: For an awesome guide
*MEGGAHGAMERHOST for some assistance in porting
*www.ShenDuOS.com
*henslo for testing my rom need more testers for a log cat as i don't have the device
*********ROM************
{ROM} (port) [ALPHA] SHENDU OS - xda-developers
G-Apps
Any help with this would be greatly appreciated thanks in advance!
4G doesnt work on any triumph ROM.
there is probably no way to get wimax to work on the triumph, though wimax is basically wireless N, it is on a different band of the spectrum and because of this I don't think there is a way to trick it into working. I'm not even sure the triumph actually has wireless N because when I looked at motorola's developer info on this device it lists wireless g but not wireless N
Just need a error logcat, see if the force close errors can be fixed if anyone can do that would greatly appreciate it, and thanks to Bfitz26 for trying to port this to the triumph and g60madman for the base
I can't run it, sorry. 4g doesn't work :(
Correct because it doesn't have any 4g radio (which I am sure you both know).
Also, no wireless N iirc.
So, enough of all of that, let's leave the 4g comments be. We know it isn't possible on the device so let the guy do his work with the rest of the ROM. :)
well sadly I needed my phone so I tried to switch to bROM, but ended up f'ing it all up. But it is stable now and i am waiting for UOT kitchen to finish my update.zip i made :D after I finish up here I shall switch over to this (after nandroid backup of this PIA of a ROM XD) and grab those logs for you. Want me to PM them to you afterwards?
If you could pm those logs to Bfitz26 over at xda would get it fixed thanks alot
I have been having internet issues :/ but it is okay, we are back online! :D Will send the log files as soon as I install Shendu. I have already sent him a message giving a heads up.
soooo is the fc issue fixed?
From what I know, no not quite. The devs need an alog cat file of why its force closing. I wanted to help and told them I would, but as you know life keep getting in the way lol internet was down for a while, I started working full time at the shop and don't get home till 2 in the morning....that stuff :P so I have the alog cat but i don't know how to send it on the XDA site....lol:D
I would use pastebin.com and send a PM to the OP with the link.
XD exactly what he told me. Already done and sent lol now all we do is wait for the outcome.
EDIT:
D/PhoneApp( 1633): Radio technology switched. Now GSM is active.
D/ShenDu_RIL( 1633): Connection is null
D/ShenDu_RIL( 1633): Do not huang up the nember
I/TelephonyRegistry( 248): notifyDataConnection: state=0 isDataConnectivityPossible=false reason=radioTurnedOff interfaceName=null networkType=0
D/NetworkModeButton( 248): Unexpected network mode (4)
was reading the log file for giggles...and noticed these strings. It repeats these lines over and over till I switch airplane mode on. GSM? Anyone want to shed light on this?
EDIT:
Sorry but think Bfitz26 has stopped even trying on this, have had a couple people at xda say they've pm's him logs but still no word,
We need more Devs in this forum.
I'm very sad ,because the Dev have stop working on this Rom.
So many Devs left the Triumph, because It's a hard phone.
I'm very thankful for Devs hard work
Hey I wouldn't be sad. I'm getting my triumph in a few days, I checked the forum to see what the community was like for it before deciding to get it...the devs managed to get gingerbread on it, they have a working, stable cm7 rom and an almost perfect cm9 rom, plus they got cm10 to boot. The Dev community for this phone is literally the #1 reason why I chose to get it.
