Root [ROM]{port} The Arctic 2.3.4
myfishbear
[ROM] The Arctic
Build Version: , by mattlgroff [OP]
(Developer)
Developer Last Online: Apr 2012 Build Version: Rating:
Released: 02-21-2012 Last Update: Never Installs: 0 Theme: Custom
No support by the author.
WARNING: FLASHING THIS OR ANY ROM BEFORE FASTBOOT FILES CAN RISK BRICKING!!!
Developed by shady_lanem
Rooted
Deodexed
PNG Optimized
Zipaligned
1% Battery Mod
Themes and tweaks
Minimal Blurs
Debloated
Cpu Optimization
Reboot option in [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]power
[/FONT]http://www.droidforums.net/forum/#
http://www.droidforums.net/forum/# menu[/COLOR]
8 toggles notification drop down
Speedy v7 scripts
build.prop tweaks
Webtop HDMI [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]Hack[/FONT][/FONT][/COLOR][/COLOR]
Dalvikvm tweak
RTL support
GPS lock/accuracy tweak
Smooth scrolling mod
Wake on volume keys mod
Ram optimization script
Supercharge custom scripts
Proximity tweak
Music app from ICS
Gallery 3D
CM7 [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]Email[/FONT][/FONT][/COLOR] app[/COLOR][/FONT][/COLOR]Based of 6.11.748 Deodexed
PLEASE DO A BACKUP AND INSTALL SAFESTRAP OR BOOTSTRAP BEFORE ATTEMPT TO [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]FLASH[/FONT][/COLOR] THIS ROM![/FONT][/COLOR]
After initial setup, choose launcher instead of Setup
Known issues/bugs:
Facebook sync not working (Solution: Added Pre-Loaded app that does this!)
Calendar widget is broken (Solution: Added Pre-Loaded widget that does this!)
4G LTE shows up as H in the status bar (Solution: Coming soon...in the entire re-theme by mopar57!)
How to install the ROM
1. Download the ROM from links provided below
2. Put it to the external sdcard
3. Boot into SafeStrap, [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]switch
[/FONT]
[/COLOR] to Safe System Enabled
4. Wipe data/Factory reset
5. Wipe [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]cache[/FONT][/FONT][/COLOR][/COLOR] partition
6. Navigate to the folder you've put the zip file
7. Choose the zip file and install
8. Reboot and wait for it to boot up
[/FONT][/COLOR]
benjiprize || Rovirar14 || nagnrik
Some notes for Droid 4 owners:
According to this thread on XDA the Arctic Rom is flashable on the Droid 4 as well.
Some things to note:
Flash as your own risk. I am doing my best to get this Rom to work better on 2.3.6 Gingerbread, and I am going to start with bluetooth.
Shady_lanem has given up Razr work and has granted me permission to his Arctic Rom.
If you are going to flash this before the fastboot files are out, do so carefully and in safestrap. (Even then I don't recommend safestrap until we get a Droid 4 version from hashcode).
For rooting use the Droid 4 Utility threads for Mac/Linux and Windows. (by skylarmb)
The Arctic 2.3.4 (fixed backlight and keyboard!)
Link: https://www.dropbox.com/s/uec6t0fr4l...v2.3.4_VZW.zip
The Arctic 2.3.3 (NOT fixed backlight yet..but brightness control works!)
MD5: c589a9cb5e43b6bf1b57ba105c01c1f2
Link: http://goo-inside.me/roms/mattlgroff...v2.3.3_VZW.zip
The Arctic 2.3.2 (Bluetooth fixed!)
MD5: 91d3bb4e119ee0da392ba04fe1173407
Link: http://goo-inside.me/roms/mattlgroff...v2.3.2_VZW.zip
