Root [ROM][PRIMOC:CDMA] MIUIv4 2.9.14 JB [UNOFFICIAL]
MIUIv4 2.9.14 HTC One V (CDMA) (Unofficial)
Installation:
1. Use the MIUI backup app to back up all your apps and settings (Ignore this if coming from another ROM)
2. Place ROM zip file in root of your SD card
3. Boot into recovery
4. Create a nandroid backup (Ignore this if you backed up with MIUI backup)
5. FORMAT ALL PARTITIONS EXCEPT SD - DO NOT USE A SUPERWIPE
6. Install zip from SD card
7. Reboot.
8. Add your google account in settings (do this BEFORE restoring, or you will have to remove and re-add it)
9. Restore from MIUI backup (if updating)
Downloads:
Kernel: DOWNLOAD (Use fastboot to flash kernel)
ROM: DOWNLOAD
If my links go down please contact me at my EMAIL
DO NOT MIRROR MY LINKS, I AM COUNTING DOWNLOADS!
Bugs:
  • Camcorder (Can not be fixed atm on any JB rom)
  • Compass (no idea whats wrong nothing in logcat)
  • USB Tethering
  • OverClock (SetCPU works fine, cant get fix till official)
  • Wether app doesnt work properly (because roms not official)
  • Bluetooth Tethering (might work i need someone to test)
If you think I have missed something please don't say
"Something force closed" I need a logcat to be able to
help you, if posting a logcat go HERE it color coats your errors.
All Thanks to:
Without these devs i wouldnt have been able to do this,
BE SURE TO THANK THEM
  • Beyond (Started the port but later handed off to me)
  • LLoir (CM10 Base)
  • Shubhamchamaria (Ported from his PrimoU Miui)
  • Seller86
  • Rukin5197
  • |0xD34D| (Miui Toolbox Maintainer)
