If you're rooted already then you have cmw. First unzip the backup to a folder. Then boot into cmw (hold down power button + volume down). Next go to restore. Then select the folder you just unzipped to. Select yes. Wait for everything to install. Select reboot. Done. Hope that helps.![]()
where can i download it? and does it support over/under clocking
Root doesn't = cmw, but I think the root method posted in the forum installs it.
Edit: in case I'm wrong about cwm being automatically installed. Here is the link to the cwm thread. [ACS] Clockwork Mod Recovery for Transform Ultra - Android Forums
ok i downloaded a rom from rom manager from toadlife(CleanGB 1.1.2) and when thats done i reboot into recovery then i go down into install zip from sdcard then i choose zip from sdcard then i scroll down into clockworkmod/ folder then i click download choose the rom the it restarts and nothing happens
ok thats cool how do i delete the all the apps that came with the rom
