ronaldramsayii
Crystal Clear Roms dev team's latest for the Droid!!!!
If you like CyanogenMod and UltimateDroid.....you may like this to.....
Sapphire 2.0.0
Changelog:
2.0.0 Added simple Matroska container support [aosp]
Pulled in support for the Matroska media container from gingerbread.
This is somewhat buggy and will need to be worked on.
Removed all market apps from the build [cvpcs]
All market apps have been removed in favor of downloading them from
the market (ADW, Musicmod, Gmail, GoogleMaps, etc). The reason for
this is to promote stability by reducing issues updating these apps.
For apps that were once available in scriptybox, they have been removed
from the switchapk script pending a more stable method of replacing
system apps (which will be included later)
Bugfixes:
Fixed search button issue with google search from market [cvpcs]
Fixed music continuous skip (hopefully?) [cvpcs]
Fixed a problem with longpress back kill dialog [cvpcs]
Longpress BACK kills current process [evan charlton/cvpcs]
If users opt-in, long-pressing BACK will kill the current
foreground process. This setting can be modified in GEM
Settings.
New AppWidgetPicker [boombuler]
Groups widgets by package when selecting which ones to
place on the home screen.
Working, simple push notifications [cvpcs]
Push notifications are now working in a usable sense. At
this point, however, they are exteremely simplistic. They
will simply be used to notify users the moment an update
or patch is available, and clicking on the notification
simply opens a page in the browser to more information.
The app will be extended in the future to become more
robust. Push notifications were also moved into GEM Settings
so as not to clutter the launcher.
Bugfixes:
Fixed some problems with volume mounting [cuviper]
1.1.7 Updated SuperUser [cvpcs]
Moved to the more up-to-date SuperUser app by ChainsDD
included in CyanogenMod. This should allow installation
of updates from Market to work.
Sapphire 2.0.0
Changelog:
Bugfixes:
Settings.
Bugfixes:
