![logouoj.png](http://img41.imageshack.us/img41/1404/logouoj.png)
DJBROM for Samsung Galaxy S I9000
(Based on Gingerbread XXJVT 2.3.5)
Compiled on 30th December 2011
Current Version: 1.14
![43772777.png](http://img861.imageshack.us/img861/7417/43772777.png)
You will notice on first install that a lof of the apps have been removed from what you would normally expect to see in the stock JVT, this is done to allow more room for your own System Apps. However, you can easily re-install the removed Apps via Addon Packs I've created, which can be installed via CWM.
Comments and feedback are more than welcome...
KNOWN ISSUES:
- AOSP Lockscreen does not work properly and so don't use this one.
![53085138.png](http://img840.imageshack.us/img840/1214/53085138.png)
- Ramad for the Deodexed JVT ROM (LINK)
- Team Obssessed Crew, Sbrissen & TSM, Birgertime & whitehawks, Dhiru, lirik0, Jkay, and untermench for the SYMPLY-GSII Mod (LINK)
- Pikachu01 for ThunderBolt (LINK)
- Cronosmachine for the APN List (LINK)
- Montymintypie for the SMS + No contact limit + No MMS convert + Sent time fix (LINK)
- Antsm for the FM Radio Mod (LINK)
- Dont Panic for the Themed Markets (LINK)
![59561996w.png](http://img221.imageshack.us/img221/1851/59561996w.png)
- Rooted / Deodexed / Zipalaigned Gingerbread 2.3.5 (JVT) ROM
- Semaphore Kernel 1.9.1 JVT
- JVT Modem / MultiCSC OXAJVT (with Daily Briefing fix on ODIN version)
- Superuser & Busybox installed
- APN List Updated to a massive 1315 entries
- Phone.apk FC / Ringtone fix
- Permanently fixed Market 2.3.6 (much better than current version)
- JVT-Mms-NoConvert-NoContactLimit-SentTime fix
- Battery Mod (shows percentage on status bar)
- Customisable Extended Power Menu
- Hosts file up-to-date with AdFree to remove most ads from your Apps
- 15 Lockscreens to choose from (Mod was 16 but couldn't get one to work)
- 13 StatusBar Toggle (both in stock and Blue themes)
- ThunderBolt 2.2.0 (with 3G, Grapihcs, bin, and libsqlite addons)
- FM Radio Mod
- Unlimited tabs in Stock Browser
- Bash / OpenVPN installed
![84022409.png](http://img638.imageshack.us/img638/4642/84022409.png)
- AdFree Android 0.8.43 (including up-to-date hosts file to block ads)
- Adobe Flash Player 11.1.102.5
- BLN control 1.2.16
- CF-Root ext4 v1.3 Addon
- ClockWorkMod Manager 2.00
- Script Manager 1.8.6 (Manual Install required)
- Semaphore Manager 0.62
- Superuser 3.0.7 / Su Binary 3.0.3
- Titanium Backup 4.6.6
- TSM Parts 2.2.1
- Voodoo Control 2.1.1
![56541953.png](http://img836.imageshack.us/img836/4848/56541953.png)
- Maps 6.0.3
- Market 2.3.6 (Disabled from updating)
- Street View 1.7.1.10
- Voice Search 2.1.4
- YouTube 2.3.4
![53935357.png](http://img828.imageshack.us/img828/2787/53935357.png)
CWM Install
- BACKUP YOUR APPS, /EFS/ FOLDER, CONTACTS ETC BEFORE CONTINUING!!!
- Copy the DJBROM_Installer_CMW_v1.14.zip file to your Internal SD Card and reboot into CWM Recovery.
- Wipe Cache and Restore Factory Settings for a nice clean installation.
- Install the DJBROM_Installer_CWM_v1.14.zip file.
- Install any other CWM Addon packs you desire.
- Restart your Phone.
ODIN Install
- Download the ODIN_DJBROM_JVT_Installer_v1.14.7z file and extract it (using WinRAR or 7-Zip).
- Put your Phonw into Download Mode (Vol Down + Home + Power).
- Start up ODIN (which is provied in the .7z archive).
- Click the PIT Button and select the s1_odin_20100512.pit file. Make sure that Re-Partition is ticked.
- Click on the PDA Button and select the PDA_XXJVT_DJBROM_v1.14.tar file.
- DOUBLE CHECK you have selected the correct files in the correct locations.
- Connect your Phone to the PC via USB.
- Press the Start button.
- After flashing / rebooting it may come up with the stock Recovery menu, just restart your Phone.
- Once it has restarted CWM Recovery will work properly, so before the launcher starts install any other addons you wish via CWM.
Converting your Phone to the ext4 Filesystem
- Go to Settings -> Advanced Options -> Ext4 Manager (Accept Superuser).
- Select "Convert to ext4".
- Your Phone will now reboot and convert the filesystem, it will automatically reboot again once it has completed.
Setting up ThunderBolt
- Go to Applications -> My Files and install the Script Manager 1.7.0 APK File.
- Once installed, navigate to bolt_scripts/Remounts/remounti9000 and click on it.
- Tick the boxes for "Run as Root" and "Run as Boot" then press Save.
- Restart your Phone, and accept the SuperUser popup for Script Manager when it appears.
![26608585.png](http://img835.imageshack.us/img835/9876/26608585.png)
DJBROM DOWNLOAD:
- CWM Version (182.68 MB): DOWNLOAD HERE - MIRROR - MD5 Hash: AA1769C6A883446CEAEC0FAB6F84E700
- ODIN Version (178.55 MB): [urlhttp://www.filefactory.com/file/c068b60/n/DJBROM_Installer_ODIN_v1.14.7z=]DOWNLOAD HERE[/url] - MIRROR - MD5 Hash: 1ED441F0BA67CBCE701B5EE858899239
ADDON PACKS:
DJBROM_Installer_CWM_PreWipe_v1.0 (139.96 KB) - DOWNLOAD HERE - MIRROR - MD5 Hash: 41B6C89588A367EC4E91670B06F97B4B
This small file is a CWM script which will delete all the data in /data, /cache, and /dbdata.
It's advised that you use this before installing a newer version, or if you're experiencing installation problems.
DJBROM_Addon_Extra_Apps_v1.11 (16.91 MB)
DOWNLOAD HERE (Installs as System Apps) - MIRROR - MD5 Hash: 24921233C5194F032C4A4072E91C7D0C
DOWNLOAD HERE (Installs as User Apps) - MIRROR - MD5 Hash: 8B5FBE9D9DA369E5BEFE5AB00B2161A8
This addon includes extra Apps that were removed from the base installation.
Here is a list of the apps included in this pack (installed as system apps).
- Aldiko Ebook 1.1
- Layar 6.0.2
- Memo 1.0
- PressReader 2.4.0914
- ThinkFree Office 2.0.110222
DJBROM_Addon_Samsung_Apps_v1.10 (14.82 MB)
DOWNLOAD HERE (Installs as System Apps) - MIRROR - MD5 Hash: 32BB1FF71F564D7BAA8FA48EC90AE3AC
DOWNLOAD HERE (Installs as User Apps) - MIRROR - MD5 Hash: 839C12422C2C0A31630E15D2AC269F17
This addon includes extra Apps / widgets that were removed from the base installation.
- Ap Mobile 11.06.03.01 (SGS2 Widget)
- AccuWeather 11.04.22.02 (SGS2 Widget)
- Buddies now 1.0
- Calendar Clock 11.02.09.01 (Widget)
- Dual Clock 1.0
- Feeds and Updates 110512.1 (Widget)
- Mini Diary 1.0
- Program Monitor 1.14 (Widget)
- Samsung Apps 2.6.114
- SamsungAppsUNA2 2.0.19
- Samsung Push Service 1.0.1
- Social Hub 7.52.6.001
- Write and go 1.0
- Y! Finance Clock 11.10.02.01 (Widget)
DJBROM_Addon_Essential_Apps_v1.02 (25.68 MB) DOWNLOAD HERE - MIRROR - MD5 Hash: F79211B88CAAA55B0627985A4808CF38
This is a small bundle of useful apps that should be a good starting point on a clean Phone.
- Barcode Scanner 3.72
- Bluetooth File Transfer 5.00
- eBuddy 3.0.2 + eBuddy XMS 2.2.2
- Facebook 1.8.1
- Flashlight 3.9.9.15
- Foursquare 2011.14.24
- GPS Status 3.8.1
- MultiPicture Live Wallpaper 0.6.8
- Quadrant Standard 1.1.7
- Skype 2.6.0.95
- TubeMate 1.05.18
- Twitter 3.0.0
DJBROM_Addon_Market_2.3.6_Update_Restorer_v1.10 (146 KB) - DOWNLOAD HERE - MIRROR
MD5 Hash: E92D91994EFFB726E558B19EE279885E
This addon will allow the Android Market to upgrade to newer versions by installing MarketUpdater.apk.
CWM_DJBROM_JVT_TouchWiz_4_Installer_v1.10 (2.07 MB) - DOWNLOAD HERE - MIRROR
MD5 Hash: 0993967A84614F8A554E8746C803BB53
This addon will uninstall the stock TouchWiz 3 Launcher and replace it with TouchWiz 4.
THEME PACKS:
DJBROM_Theme_Stock_v1.10 (10.33 MB) - DOWNLOAD HERE - MIRROR
MD5 Hash: AF2150F7B1A4711119564274FE5A7D96
Just in case you want to revert back to the Original Stock theme and TouchWiz 3.
DJBROM_Theme_Blue_v1.10 (9.41 MB) - DOWNLOAD HERE - MIRROR
MD5 Hash: E1C3F2721393C4DC628B2EF49923EDAA
![34634580.png](http://img11.imageshack.us/img11/3736/34634580.png)
Standard Install
Phone Info and Quadrant Score before ext4 conversion
![djbrom113100.jpg](http://img834.imageshack.us/img834/6571/djbrom113100.jpg)
![djbrom113101.jpg](http://img812.imageshack.us/img812/7148/djbrom113101.jpg)
Home, Notification, and Application Screens
![djbrom110102.jpg](http://img263.imageshack.us/img263/2451/djbrom110102.jpg)
![djbrom110103.jpg](http://img207.imageshack.us/img207/3144/djbrom110103.jpg)
![djbrom110104.jpg](http://img854.imageshack.us/img854/8631/djbrom110104.jpg)
Phone Dialer, Extended Power Menu, and Market Screens
![djbrom110105.jpg](http://img600.imageshack.us/img600/3339/djbrom110105.jpg)
![djbrom110106.jpg](http://img823.imageshack.us/img823/3781/djbrom110106.jpg)
![djbrom110107.jpg](http://img339.imageshack.us/img339/9163/djbrom110107.jpg)
Quadrant Score after ext4 conversion
![djbrom113201.jpg](http://img715.imageshack.us/img715/2752/djbrom113201.jpg)
Blue Theme Addon
Home and Notification Screens
![54135627.jpg](http://img689.imageshack.us/img689/3972/54135627.jpg)
![djbrom110302.jpg](http://img443.imageshack.us/img443/806/djbrom110302.jpg)
Phone Dialer and Market Screens
![djbrom110303.jpg](http://img12.imageshack.us/img12/48/djbrom110303.jpg)
![djbrom110304.jpg](http://img210.imageshack.us/img210/2415/djbrom110304.jpg)
TouchWiz4 with Blue Theme
Home and Application Screens
![djbrom110401.jpg](http://img840.imageshack.us/img840/7473/djbrom110401.jpg)
![djbrom110402.jpg](http://img802.imageshack.us/img802/5574/djbrom110402.jpg)
![24725677.png](http://img259.imageshack.us/img259/5356/24725677.png)
v1.14 (2011-12-30)
- Updated Script Manager to 1.8.6
- Updated Swype to 2.28.70.19880
- Updated TSM Parts to 2.2.1
v1.13 (2011-12-23)
- Installs Script Manager APK TO SD Card for Manual Installation
- Updated BusyBox to 1.19.3-Stericson
- Updated Titanium Backup to 4.6.7
v1.12 (2011-12-19)
- Downgraded Script Manager to 1.7.0
- Included the final fix for the SYMPLY-GSII Mod
- Moved Script Manager and Titanium Backup to main Installation
- Moved User Apps to Essential Apps Addon Pack (CWM)
- Updated Carrier Text
- Updated Flashlight to 3.9.9.13 (Essential Apps Addon)
- Updated Maps to 6.0.3
- Updated Skype to 2.6.0.95 (Essential Apps Addon)
- Updated Titanium Backup to 4.6.6
- Updated ThunderBolt to 2.2.0
v1.11 (2011-12-15)
- Added User Apps for CWM Install
- Moved Script Manager and Titanium Backup to User Apps
- Updated Adobe Flash Player to 11.1.102.5
- Updated Maps to 6.0.2
- Updated ThunderBolt to 2.1.9
v1.10 (2011-12-11)
- Added Layer 6.01 to Extra Apps Addon
- Added Ap Mobile 11.06.03.01 (SGS2 Widget) to Samsung Apps Addon
- Added AccuWeather 11.04.22.02 (SGS2 Widget) to Samsung Apps Addon
- Added Samsung Push Service 1.0.1 to Samsung Apps Addon
- Added Titanium Backup 4.6.5.1 to main Installation
- New Theme based on SYMPLY-GSII Mod by Team Obssessed
- Updated AdFree Android to 0.8.43
- Updated Maps to 6.0.1
- Updated ThunderBolt to 2.1.7
v1.07 (2011-12-02)
- Added missing programs from Google Apps Package 2011-08-28
- Updated Maps to 6.0.0
- Updated Semaphore Kernel to 1.9.1
- Updated Street View to 1.7.1.10
- Updated ThunderBolt to 2.1.4
v1.06 (2011-11-28)
- No confirmation popup in Reboot, Recovery and Download
- Updated ThunderBolt to 2.1.3
v1.05 (2011-11-24)
- Downgraded Script Manager from 1.8.1 to 1.7.0 (better version)
- Removed System/Browser Lag Fix as it was useless
- Updated Semaphore Kernel to 1.9.0
v1.04 (2011-11-23)
- Added Bash and OpenVPN
- Added FM Radio Mod
- Added Script Manager 1.8.1
- Added Stock Browser 8 Tabs Mod
- Updated Maps to 5.12.0
- Updated Semaphore Manager to 0.62
- Updated Superuser to 3.0.7
- Updated ThunderBolt to 2.1.1
- Updated YouTube to 2.3.4
v1.03 (2011-11-07)
- Added System/Browser Lag Fix
- Upgraded Kernel to Semaphore 1.8.2
- Added ThunderBolt 1.8.0 + bin + libsqlite addons
v1.02 (2011-11-06)
- CWM Version no long force wipes Data + Cache, only the System folder
- Added JVT-Mms-NoConvert-NoContactLimit-SentTime fix
- Added 14 StatusBar Toggle (both in stock and Blue themes)
- Updated Voice Search to 2.1.4
v1.01 (2011-11-02)
- Added Angry GPS, Voice Dialer, and BLN control to the base install.
v1.0 (2011-10-31)
- Initial Release.
