DISCLAIMER: By using this rom, you agree that you are the only one responsible for anything good or bad that may occur. Use at your own risk.
For Cricket ZTE Source N9511 only.
This is completely unmodified Stock JB 4.1.2.
hera_stock_B07_with_recovery.zip UNTESTED
hera_stock_B09.zip without recovery
This is completely unmodified Stock B09 JB 4.1.2 with Root.
hera_stock_B09_root.zip
This is Stock B09 JB 4.1.2 debloated and deodexed with root.
hera_stock_B09_deodexed_root.zip
NOTE: These zips are unsigned so you will need to disable signature verification in cwm before flashing.
NOTE2: Your device must have CWM to flash ROMs. If it doesn't, please check out ZTE Source CWM Flasher
Flash this in CWM as follows:
Other Downloads:
hera_B09_partitions.zip - The B09 update also patches several partitions. I am not sure if this is needed but flashing this zip will update your partitions for you.
NOT_FLASHABLE_hera_B09_deodexed_removed_files.zip
Thanks to:
Krsmqn - Uploaded the update zip
cooldudezach - Uploaded system files and tested.
- Download ROM of choice
- Put the ROM.zip on your sdcard if not already
- Reboot to CWM Recovery
- MAKE A BACKUP!!!!!!!!!!
- Wipe data/Factoy reset
- Install ROM.zip from sdcard
- Reboot
- Enjoy!
Other Downloads:
Thanks to:
