Root [ROM] Stock FC17 Rooted/Deodex/
THIS IS NOT MY ROM .. I HAD NOTHING TO DO WITH THE CREATION OF THIS ROM... ALL CREDIT GOES TO chrystal0925 OVER IN THE XDA FORUMS .. WITH THAT SAID HERE IS A LINK TO THE ORIGINAL POST AND WHAT IT CONTAINED.
ORIGINAL POST : [ROM] Stock FC17 Rooted/Deodex/ SPH-D600 Conquer - xda-developers
First Im not responsible for anything that happens to your phone..
this is based off stock FC17 update
note: only zips in this first post are stable any posted in the forum are test and may not work..
*rooted boot.img
*deodex
*zipaligned
*bash/shell support
*init.d support
*memory tweaks
*system RW
*crt off animation
*reboot power mod
*custom boot animation support
-rename boot animation to sanim.zip copy to system/media :]
download Rom here:
https://www.dropbox.com/s/imiwgm1np7...600-signed.zip
download reboot power mod attatched just flash in recovery :}
COTTON CANDY THEME:
http://db.tt/CYHVpKJv
download new ICS theme here:
http://dl.dropbox.com/u/46879286/CON...-ICS-THEME.zip
theme update wimax icon
http://dl.dropbox.com/u/46879286/CON...CS-update2.zip
theme includes power mod no need to flash it after or theme will be gone
please make sure your able to restore a back up in case its needed.
so make back up
New updatezip by stewiemakkin no need to format before flashing rom
install zip from sd card reboot phone
included an alternate phonesky.apk(vending/market) if this has trouble try renaming it to vending.apk
also no stock launcher I included adw use what ever launcher you choose till I can get stock one deodexed
if rom is not booting try data factory reset then flash rom..
if it will not boot at all restore your back up..
on first boot it will take time wait atleast 10 min to verify before restoring..
also i dont own this phone so please report issues..
more sreenshots to come:
thanks to TikiRatt and itzdarockz for screenshots and testing [being my guinea pigs through numerous tests] :]
