shahabazas
~*~ Android Addict ~*~
SURPRISE ROM
Some Feature of SURPRISE ROM
* Android 2.3.5 Pre Roooted
* Bravia Engine & Beats Audio
* Inbuilt data2Ext support
*Transprent Dialer
*New Msging in app style
*Compact Notification Bar
And Many More once you use it you will come to know.
Credits:
Mmrehman for Rebuilding the ROM with the missing things like Account and Sync and also making it more stable.
MEfor porting and testing it on A75 and providing the fixes.
And to all the AFMMX MEMBERS as they have always inspired me and had helped me whenever i stuck in something. Buddies miss u a lot.
Disclaimer/Warning:
I AM NOT RESPONSIBLE FOR ANY HARM DONE TO YOUR PHONE USING THIS . DONT BLAME ME IF YOUR PHONE TURNS INTO A PAPERWEIGHT/BRICKED USING THIS. DO IT ON YOUR OWN RISK.
How to flash well its the same way you flashed the other ROMs still wanna know ok
Installation:
1. Download the zips from Download link
2. Dump it to SD card
3. Reboot to recovery
4. Factory reset
5. Wipe cache
6. Go to Advanced
7. Wipe Dalvik Cache
8. Wipe Battery stats
9. Go back
10.Select install zip from SD card.
11.Select the ROM zip
12.Select Yes
13.After the flashing complete go back
14.Flash the Camera fix and the Volume Fix.
15. Reboot
16.........ENJOY.......
First boot takes about 3 minutes.After first reboot, Open file explorer and go to SDcard ,Here you find Scripts folder and 01data2ext file.
JUST MOVE THIS FILE(01data2ext) TO Scripts folder AND REBOOT ONCE AGAIN.Second boot also takes about 3 minutes.
NOW OPEN SYSTEM INFORMATION & SEE THE INTERNAL MEMORY.
NOTE:SIM background colour wont work as it is modified to display new icons on signal strength.
As general rule BATTERY SHOULD BE CALIBRATED EVERY TIME WHENEVER YOU FLASH NEW ROM.So calibrate your battery properly.
Here are the download links:
ROM Download
SURPRISE ROM WITH ALL THE UPDATES Special Thanks to RAJWORLD DHAKA for uploading this ROM on 4Shared and to Amolmendhe for treasuring the ROM and sharing the link.
Volume Fix
Volume Fix
ENJOY THE SURPRISE ROM... Hope you all like it...
Screenshots:
Sorry I dint have any at this moment so you people can provide the screenshots once you finished flashing the ROM.
*Transprent Dialer
Credits:
Disclaimer/Warning:
Installation:
4. Factory reset
5. Wipe cache
6. Go to Advanced
9. Go back
12.Select Yes
15. Reboot
ROM Download
Volume Fix
Volume Fix
Screenshots:
