rom to flash
I have a HTC HD2 that was on windows but is now on android.
I installed the following in order to change it.
HSPL: 2.08
MAGLDR: 1.13
Radio: 2.15.50.14
Then I went to bootloader and choose USB Flasher and installed
DFT_LEO_NAND
Is there a rom I can install in the same way...I dont know very much so any help will do.
best regards
I would go over to the XDA forums, they are more active and can probably help you out more. I'm not sure what dft_leo_nand is? I would simply read the directions for whichever ROM you pick and make sure it's the right ROM for your phone.
HTC HD2 Android Roms
I'm using the Frankinstine one and it's pretty awesome.
