use No-frills CPU control. go into the settings and check disable safe valve. restart and then what ever values you set will stick
That's cool I am actually using SetCpu at the moment. I want to tweak my phone a bit more with the plague kernel though. So you see were i am having a problem.
you don't have to use the app to run the values, just let everything stick, I use rom tool box for everything but use that setting in No-frills to get everything to stick.
If you want to change the sd boost it needs to be done as its booting if it continue not to work just download from the market and change to what ever value you want
