[ROM] [Triumph] Froyocream Sandwich v2.0
Status
Not open for further replies.
ziggy46
Android Expert
by Ziggy and Mobstergunz
Rom Features:
Rooted
Busybox
ICS launcher
Custom unlock/lock sounds
Custom fonts
Custom splash image
Custom boot animation
ICS icons
Themed Notification Bar
Themed Volume Bar
1% battery MOD
performance tweaks
ICS keyboard
Black MMS - thanks to b_randon14
fOCkv1.1.2 - thanks to mantera
ICS ringtones, alarms, ui, and notification sounds
Custom Shutdown
Silent boot and shutdown
Camera and video tweaks from the sony bravia
New design elements - thanks PimpinEZ
Mobster Tweaks (improves battery and visual experience)
Icecream Sandwich themed Power widgets in status bar
(thanks to b_randon for helping get them working correctly)
2 more keyboards thanks to b_randon14
Rom name as carrier
Reboot and Recovery mod
HD Youtube
new performance tweaks and mods
white menus to fix black text on black background issue
Do Not Flash Gapps with either Rom or Theme
Installation Instructions: For Full ROM - includes theme
1 Backup
2 Wipe data/factory reset
3 Wipe cache partion
4 Install ROM
5 Reboot
Link- Froyocream Sandwich v2.0.zip
Installation Instructions: For Just The THEME
this is only the theme not a full rom you must be
on stock 2.2 and deodexed before you install this
1 Backup
2 Wipe cache and dalvik cache
3 Install THEME
4 Reboot
5 restore launcher pro backup
in prefrences
Link - Froyocream Sandwich v1.4 theme
DISCLAIMER: WE ARE NOT RESPONSIBLE FOR ANY DAMAGE DONE WHILE USING THIS ROM
Original Thread<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
If you have any bug reports, please post them in this thread
Future Plans:
  • Add ICS Window Animations to framework
  • Add some new performance tweaks
  • Change some notification icons (install finished, email, gmail, and mms)
LET US KNOW IF THERE'S ANYTHING YOU'D LIKE TO SEE ADDED
Change Log: (newest first)
v2.0
  • Redone system (fixed most problems)
v1.4
  • Added new battery tweaks
  • Added 2 more keyboards (thanks B_randon14!) <-- there awesome
  • Added Status bar power widgets w/ b_randon14's help
  • Added custom carrier name
v1.3
  • Added video and camera tweaks from the sony bravia
  • Added new design elements (thanks PimpinEZ)
v1.2
  • Added new shutdown animation
  • silent shutdown fix
v1.1-
  • Added Dsp Manager
  • Added Thunder.prop (thanks to JollyRoger87)
v1.0-
  • Rom Created
Video Installation: (thanks minus5252)​
How to install Froyocream Sandwich V1.4 on the Triumph
We'd like to thank everyone who uses this rom, and provides both positive and negative feedback.... it helps us improve upon it and make it the way you guys want it.
I'm munching on some cream sandwich right now and got to tell you its smooth and creamy every thing works and hell anything cm7 cane do you can do with an app so what's all the fuss about cm7 the touch screen never worked this good on cm7 just saying;)
And the build props props for the build props as well as the LCD density looks really clean.
I am staying on this one
When you long press the launcher gives you options like Widgets or shortcuts click shortcut then direct dial and choose a number to add to your home screen try it and tell me if yours works cause mine doesn't do anything when I tap it it doesn't call the person lik e I'd should maybe it has something to do with your modded phone.apk but direct message works fine . So for now I'm just dialing my wife the old fashion way
FCS v1.4 is worked for me but every time i try to flash/install FCS v2.0 it is giving me error "installation aborted" "status 0 error"
Please help..
I'd kinda like the gingerbread thing that it does when you press the power button and it makes a TV animation, if its too much to ask for, ill understand.
That would be near impossible I've never heard of a Dev getting the CRT animation ported to a Froyo Rom however I have seen it in CM9
Ok I have a major emergency!!! I changed the font in launcher settings and now the launcher wont even open! It force closes!! HELP!!!!
Ok ok....... I got it...... I went into titanium backup and wiped the data for ics 4.0 launcher and it worked
i jst trying to say to the developers plzzzzzzzzz fix the bugs of this rom
i jst flashed it on my micromax a70 all wer ok bt only one problem whenever m trying to open call setting it shows FORCE STOP everytime plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz fix it as early as possible
This Rom isn't meant for the Micromax a70 its for the Motorola Triumph
Status
