Doc
Android Expert
Ok guys here is one from Goddly, this thing is very sweet and runs very well......
http://forum.xda-developers.com/showthread.php?t=2213763
White Out Rom V.5
------------ Not Responsible For Your Equipment, Flashing Anything, Always Has Risks-----------
Check out this ROM from a clean flash. Follow instructions in the OP and throughout this thread. I'm showing here where you start off, as well as a few highlights from the many awesome options possible due to tdunham's AIO mod. So you take it from here. I did make sure to grab the boot animation in here.
Screenshots
To get the toggles seen in the screen shot -- 3Minit Settings in apps- Use Toggle Mod / Check it.. ---
Starters
Version 3 and 4 dirty install version on a clean install bootlooping issues caused by transparent weather widget.
NEW- Please give at least 1 full empty-charge cycle for true battery results.. you will not be disappointed
NEW - Added Agat 1.3 Custom Recovery
- TW GB27 - Being a Jelly Bean rom , Jelly Bean Modem is needed.
- JB Modems can be found here
http://www.rwilco12.com/downloads.ph...0%29/Modems/JB
- TW GB27 - Recommend GB27 Kernel , The Rom flashes Agats 1.3 Kernel
Base
- Base is GB27 (thanx g_ding84)
- Bloat removed (thanx g_ding84)
Add Ins
*NEW - * * * - Gharrington........3Minit framework (Very awesome app *)
*- Tdunham...........For porting over the 3mint app for us.
NEW - AIO Rev 4.0 by Tdunham (thank him, he does alot of good work
-Changes-
Version 5.
Flare lock screen (Gding)
Bilgerryans's sound mod (Bilgerryans)
Modded stock smms (mine )
AIO 4.0 (Tdunham)
3minit V.3.0.1 (Gharrington)
New Framework animations , super cool (thanks for the find Cerj)
Modded in call color change added (mine )
Added S4 accuweather widget
Added S4 Sounds (ringtones, alerts etc)
Changed toggle colors from white on black, to black on white (stock toggles)
Changed power off buttons (hold down power) to white (except boot loader)
Changed the blurry white typing line back to stock blue (bad 9patch)
Charging animation transparent now and smaller
Removed Both white icon sets (30 mb of system space) you know where to find em... lol
Updated supersu to V 1.34
S4 shutdown animation (untested)
Glass Apps- (TeamBlackout and TUN_SD) also Gamerpro for the suggestion
PlayStore
Google Maps
Gmail
they have a bunch of inverted apps aswell like facebook, Google Drive, Dropbox etc.
located here http://www.inverts.cajunflavoredbob.com/
Version 4.
- AIO 3.5 with tabbed settings etc.
- Kernel , Agat 1.3
- S4 Weather Widget (Fully Transparent)
- White Out Themed AOSP messaging app, replaces stock (much better)
- Added Popup Browser ( thanks Gyebro )
- More Transparency through out the framework,
- Removed the white out pulldown image (fully Transparent)
- Stock contact images to white ?.. matching contact pics in the new messaging app
- SystemUI mods
- Based off of V2 hopefully clean flashable
Version 3.
- 4.1 Kernel/Recovery
- AIO Rev 3.3
- New Playstore
- Transparent E-mail Fix
- Contacts Image Changes
- Dial Pad Mods
- Transparent Stock Toggles
- PullDown Image ( White-Out )
- Bottom Bar Changed (pulldown)
- Added Mods to Phone.apk images
- Fully Transparent Accuweather widget
More I'm Sure.......
- Apps
- Popup Browser, https://play.google.com/store/apps/d...9mdC5wb3B1cCJd
- Nova Launcher https://play.google.com/store/apps/d...5sYXVuY2hlciJd
- Deep Sleep Battery Saver https://play.google.com/store/apps/d...mF0cnNhdmVyIl0. (deep sleep on screen off app)
- Greenify https://play.google.com/store/apps/d...Z3JlZW5pZnkiXQ..
- Night Mode https://play.google.com/store/apps/d...aWdodG1vZGUiXQ.. (works great with the brightness of the white)
- Disable Service https://play.google.com/store/apps/d...lIl0.(disables unwanted services, Use with caution
- Desktop Visualizer https://play.google.com/store/apps/d...cC5kc2t2enIiXQ..
- UCCW Ultimate Custom Widget https://play.google.com/store/apps/d...b213aWRnZXQiXQ..
- Bilgerryans Total Mod thread http://forum.xda-developers.com/show...php?p=41342834
Mods Super Thread
Thanks
g_ding84- His Rom as a base, and helping with my questions
Kobridge- CRT Animation off and all his work hes done for us all.
Shadow_God For putting in a ton of work for the community as well
Exit_Only
Phakker
Tdunham- Putting in a ton of work and great additions to roms +1 to you sir *Bows*
JDSingle76- Testing
V.1 V.5
NEW - SeriouslyCrazy Letting me post his Clock skins (slightly modded) and his SC58 gray light Icon pack
Installation
- Odin to EL26 Recovery (mobile Odin or One click) Or using a Custom Kernel From Garwynn or Agat recovery http://www.rwilco12.com/downloads.ph...1g/Stock%20CWM
- Once in recovery Wipe Cache And Dalvik (good policy)
Flash JB Modem From EL26 (EL29 Directboot has problems with Modem Flash---You have been warned---)
If not already on one.
- If coming from ICS (Ice Cream Sandwich) A Full wipe / Format all , is needed
Jellybean Format All -- by Tdunham found here http://forum.xda-developers.com/show....php?t=2077277
- Flash W_O_R.v. of your choice and Enjoy.
- For People Looking For Custom Recovery-
NEW - Custom Recovery Kernel for GB27.( see above )
Mobile Odin- App in the market 4.99, Probably wont be used too much more in the coming days, but youll always have it if purchased, no matter what device you own.
Download Garwynn 5.0 or Agats 1.3 .Tar Flash In Mobile Odin, OR the .ZIP ( flash in another recovery, then "advanced" "reboot recovery")
Download EL26 CWM.tar .TAR.. http://www.rwilco12.com/downloads.ph...tock%20CWM/TAR
Though you can One Click the el26CWM.exe .EXE http://www.rwilco12.com/downloads.ph...0CWM/One-Click
if you dont have Mobile Odin
Downloads
Carbon Background White-Out
White_Out_Carbon_background.zip
NEW~W_O_Rv.5.zip Md5- d2d8d89954560872b167d43d89b97817
http://www.androidfilehost.com/?fid=23017610006233515
W_O_Rv.4.zip (Dirty Flash Only) Md5- 621d8e835464dcfc94c8b2d762cd29ee
http://d-h.st/j75
CLEAN INSTALL Version 4 (removed transparent weather widget )
http://d-h.st/Anh
W_O_R.v3.zip (Dirty Flash Only) Md5 - abdec1aaf45b9d2a0db00e98c2866488
http://d-h.st/J2v
- For those who want the (graciously named "Pity Tha Fool!") white setup Look to post #3
For those who want the White 2 Black
Tornado and the default tornado isnt showing up for the lock screen. Here settings, display, wallpapers, lockscreen, use the "yellow flower" gallery for both , do not resize it or move it. that way it will go from white to black after unlock, looks cool...
Different Contact Images here
http://forum.xda-developers.com/show...13763&page=33#
:smokingsomb::smokingsomb::smokingsomb:
White Out Rom V.5
Screenshots
Starters
Base
Add Ins
-Changes-
Version 5.
AIO 4.0 (Tdunham)
PlayStore
Google Maps
Gmail
Version 4.
- Kernel , Agat 1.3
- SystemUI mods
Version 3.
- AIO Rev 3.3
- New Playstore
- Dial Pad Mods
- Apps
Mods Super Thread
Thanks
Exit_Only
Phakker
JDSingle76- Testing
Installation
Downloads
http://d-h.st/j75
http://d-h.st/Anh
http://d-h.st/J2v
