Root [ROM][UNOFFICAL][5.1.1] BrokenOS 2/11/2016
phenomx4
Android Expert
Recognized Developer
This is a unoffical release of BrokenOS for the Zte Warp Sync so please don't expect this to be 100% stable. Before flashing this rom I recommend you make a backup just in case. Please report and bugs you encounter, preferably with a logcat.
What works:
  • Audio/speaker phone
  • Camera
  • Headset/headphones
  • Calls and texts
  • Touchscreen
  • Lights/brightness
  • Offline charging
  • External SD
  • Bluetooth
  • Wifi
  • sensors
  • MTP
  • GPS
  • Tethering
What's partially working:
  • Nothing
What's not working:
  • Nothing
Issues:
Change Log (source)
Click
Change Log
HTML:
2/11/2016
Initial release
Credits and thanks:
BrokenOS
Hroark13
ZTE
Patches:
none
Gapps:
https://github.com/cgapps/vendor_google/blob/builds/arm/gapps-5.1-arm-2015-07-17-13-29.zip?raw=true
Download:
https://basketbuild.com/filedl/devs...oken-v3.9-warp4-5.1.1-UNOFFICIAL-20160211.zip
Screenshots:
Comming Soon
While donating is not required to use this rom it's always appreciated
Donations:
Nice Rom! So far everything seems to be running smooth. Very light and quick , one thing thou does not have a music player.
So far Broken Rom not bad but noticed the camera not working right. It takes pictures but a lot of the times doesn't specially when flash is on. Great job thou.
I link M camera on tipsy link u can't tell me that one don't work I checked
Ur right i can't but that's only because never tried it lol!! Besides i'm running BlissPop since Broken would make my Sync get hot real fast for no apparent reason. So far Bliss seems the best one to me.
with this rom...having a conflict...I use Scannator OBD-2 with a bluetooth module to check engine codes ect...with stock rom this app works flawlessly... But with this rom my app freezes when trying to connect to bluetooth...have un-installed and re-intalled app 2 times with same effect...with my old warp ...any rom I used this would work...Only glitch I have found so far.
Do u have busy box installed some times if it not installed on custom Roms some thing will freeze from my experience could b wrong worth a shot I'm on broken my self
