Root [ROM][UNOFFICAL][5.1.1] Nameless Rom 1/08/2016
phenomx4
Android Expert
Recognized Developer
This is a unoffical release of Nameless Rom for the Zte Warp Sync so please don't expect this to be 100% stable. Before flashing this rom I recommend you make a backup just in case. Please report and bugs you encounter, preferably with a logcat.
About (Taken from Nameless website)
What is NamelessRom ?
Simple - NamelessRom is opportunity. An opportunity to have a voice to the development team of the after-market firmware that you run on your device. The main goal of NamelessRom is to provide quality development for android devices, phones and tablets alike. NamelessRom developers are available nearly 24/7 and respond to bug reports and feature requests almost instantly. This availability will allow you, the end-user, to have direct input into exactly what features and functions are included on the firmware that YOU run. NamelessRom == endless possibilities. Unless you have an iPhone, then you're out of luck.
What works:
  • Audio/speaker phone
  • Camera
  • Headset/headphones
  • Calls and texts
  • Touchscreen
  • Lights/brightness
  • Offline charging
  • External SD
  • Bluetooth
  • Wifi
  • Proximity sensor
  • MTP
  • GPS
  • Tethering
What's partially working:
  • Nothing
What's not working:
  • Nothing
Issues:
Change Log (device)
HTML:
2/11/2016
Added new wifi driver
add power hal
1/08/2016
Fix touchscreen/lockscreen freeze
Added DspManager
Test out battery drain fix
12/30/2015
Fix 3G
Initial release
Credits and thanks:
Nameless
Hroark13
ZTE
Patches:
Gapps:
https://github.com/cgapps/vendor_google/blob/builds/arm/gapps-5.1-arm-2015-07-17-13-29.zip?raw=true
Download:
https://basketbuild.com/filedl/devs?dev=phenomx4&dl=phenomx4/N9515/nameless-5.1.1-20160211-warp4.zip
Screenshots:
Comming Soon
While donating is not required to use this rom it's always appreciated
Donations:
I believe I have found a problem. Before switching to this ROM I used the built in Sync feature on Android Carbon. I had it on for at least 4 hours and when I was doing the installation process and signed into my google account, it said my last backup was 8 days ago. So not too sure if I am doing something wrong or it is just not working.
Just select new device that's what I always do
When on new ROMs, sometimes have to manually go into settings/accounts and manually switch on the Sync buttons
I have notice the WiFi range is low. I can be upstairs and the route is downstairs and I can't do anything. It's not my carrier I already checked. I when back to stock briefully and my WiFi is perfecrly fine it's just this rom and carbon with these problems
My HTC is bricked.I have not any backup and tried to find one ROM for that
Do u know any page help me?
Google is your best bet. [emoji43] You never flash another device model's ROM on another device unless they were made by the same Mfgr, same OS, and are specific hardware twins. Even then, you may have potentially serious issues. [emoji48]
