Root (ROM)(Updated) LG Motion Bella v3 - Merry Christmas
Bard
Android Expert
Intro
Alright, time to update this old ROM again.
This is a light weight, trimmed down and customized ROM.
If you want more LG-like experience with more themes, try Motion Year 2014 ROM instead.
ROM DESCRIPTION
One of the oldest Custom LG Motion ROM since the device launched.
Made from Firmware G phone from the scratch.
Loki ported insecure Kernel
Zipaligned, deodexed, well debloated
Wifi Scan Interval increased from 20 to 120 for battery saving.
Lightweight (under 400mb)
Comes with updated Apps (as of 8/8/2014)
Zeam Launcher, Google Keyboard, Quickview
Viper Audio (need to be activated by user)
WARNING
You must fully aware of installing custom rom with modified kernel.
Make sure to back up your phone and follow install guide step by step carefully.
I am not responsible for bricking / damaging your phone.
Download
Firmware G - V4 (WIP)
Firmware F - V3 (Loki port, GT's overclock kernel)
Dev-Host - LG_Motion_Bella_V3.zip - The Ultimate Free File Hosting / File Sharing Service
Prev Release V2 (Loki port, Modified Stock Kernel)
Dev-Host - MS770_Bella_v2[2].zip - The Ultimate Free File Hosting / File Sharing Service
Prev Release (stock kernel)
Dev-Host - l0_signed_Bella_beta2.zip - The Ultimate Free File Hosting / File Sharing Service
INSTALL
1. Download the ZIP file from d-h.st then copy it on the root of external-SD card.
2. Go to CWM by clicking Reboot Recovery @ 2nd-init Recovery app
3. Back up your current rom to your SD card if you haven't done it already.
4. Wipe data/factory reset
5. Wipe cache partition
6. Advanced -> Wipe Dalvik Cache
7. Mount and Storage -> format /Cache
8. Mount and Storate -> format /Data
9. Mount and Storage -> format /System
10. Switch to External SD Card by clicking Home button
11. Install Zip from sdcard
12. Choose the .zip file you downloaded and placed on the SD card
13. Wait until installation finishes.
14. If you see any error during installation, DO NOT reboot.
Restore your phone with pre-made Nandroid backup.
15. If install was success Select 'Reboot System Now'
16. First reboot will take long. Dont' panic.
17. Once it boots, set up your account & test all functions.
SCREENSHOTS
Update Log
12/05 - version 3, GT's Freedom Kernel, updated apps, new wall papaers.
07/12 - version 2, loki port, custom kernel, updated apps
02/14 - reworked from scratch using scrub's base rom, wifi fixed
02/11 - initial release, wifi problem
My thanks to
Scrubtasticx - base rom
djrbliss - Loki port for LG Motion
Game Theory - Freedom Kernel
Johnnyl1111 - Flashable F-aboot
Shabbypenguin - Modified Stock Kernel (removed security check script)
Sammyz - unbrick guide
Cretinoid (Hroark13) - root and recovery program, CM10 updater-script
985hPaKick - 2nd init recovery app
You - brave enough to download and use my humble rom lol
DONATION & THANKS
I've done all my testing and developing with my day-to-day phone -_-;;
Little support will definitely get me going for future project and development
1. You can come to my homepage and click pay-pal donation link.
2. Or you can click Google Ads on my homepage
3. Or you can just say thanks / hit thank button / give me support on future project.
I worked with scrubtasticx's base rom and made wifi to work.
Rom is getting uploaded. Will provide link and update post soon.
Woohooo!!!
Why is this in beta stages?
You and scrub should team up with ayybee. He has lg keyboard working and his rom skinny. In new theme or rom can you get Google now preinstalled , along with some speed tweaks,? When I have time Ima make magical uot themes and try to flash. Also if you guys like you can Cherri pick from it or just add zazzle. Bazinga!
Yeah collaboration works sounds fun. It will be an another fun side project while perfecting Bella.
What would be a good name for collab rom?... just LG-MS770 Collab Rom? haha :)
Thanks for bump :) I removed beta tag from the title. It seems like ROM is stable enough for daily use.
