ROMs [ROM] v5.0 Lolipop Nightly For LG Motion MS770
  • Start date Start date
Do you Recommend This Build?
  • Total voters
    5
D
Deleted User
Guest
Hello hope y'all had a good week, well i did too so far i spent most of the month building this by myself and coding it correctly well this is a Nightly build
For those who don't know what a nightly build is..well basically is a build that hasn't been perfectly rid of bugs so as updates progresses bugs that are present will be resolved in future updates and will become a stable build.
Well as Lolipop came out i decided to go out of my personal life to build a os for the Lg motion ms770 heres whats new:
Changelog:
* improved walkman and added walkman extentions
* Improved Lolipop Launcher and is updatable via Google Play Store
* keys are updated and build keys are now release keys for the build
* Improved Wording in settings
* Improvements and more.
What's Broken:
* when tapping the os version will display jellybean witch the os is not jellybean
Download http://www.4shared.com/zip/tqMES7RTce/cm12_Nightly_for_lg_motion_ms7.html
Dont install i found a bug that just keeps staying on boot anumation dont install yerlt ill be releasing a later today est time please be patient the systemui..apk is faulty and no lonfer works im fixing it as we speak
Its late so I'll download tomorrow and test it and let you know how everything runs for me. I can't wait to try this, thank you!
If you do make sure you backup your current rom or have a bsckup flashavle zip im thinkimg tbe systemui.apk is preventing full boot abd is making system stay at boot animation please keep that in mind we are going to fix this issue layer this evening est time thsnks and thank god i caugjt onto it in time!!!
Well thanks for seeing if it does be sure to have a backup rom to reflash your old rom back
I tried to install but I keep getting Status 6 Installation Aborted.
Hmm i think ik what it is is the updater-script its causing a install error it might be currupted or somrthing in coding might be incorrect ill look into it and release the fix in the next update
