Just read this post... Are you serious? lolAlso ofcourse no one cannot learn anything on their own without one depending on some sort of information. Even reading a book depending on the authors way of explaining things is holding your hand to what is needed to be acknowledged, just saying.
I want to uninstall some applications to make room for Kali Linux on the internal storage side. What are some apps that some people removed after flashing to lucidian? Is there a list some where?
I have 3.2 GB left to use, I just need a total of 5 GB for Kali, so that's like 2 GB more space.
Hmm odd, I have 16gb external sdcard with 9gb left. I opened the terminal and did gunzip on bt5.img from the sdcard in cd /storage/sdcard1/bt5, it tells me that the bt5 img does not fit.... how can 5gb not fit on a 9gb ;/ must be doing something wrong idk.
You have to realign the annular confinement beam to a broad band spectrum and then reinitialize the warp core. Then, after you gain access to the primary computer mainframe, you have to disengage inertial dampers while boosting power to the deflector dish.
Am I the only one experiencing an issue with cwm recovery not working for the Lucidian Rom
I have an idea of what it is. I think it might be left over data from the non working recovery app install.
Let's try this to see if it works...
Click your menu button and go to manage apps. From there select the recovery app. Now before uninstalling it, hit the clear data button and then uninstall it and reboot. Install recovery from here and see if it works.
You may have tried this already too, but I figured I mention it anyways since people usually uninstall apps without clearing data first.
Ok so sounds like it is leftover data.
Lets try to find it.
Go to internal SD and see if you have a folder named "0". Then come back and let me know if you do.
