blaxican25
Android Expert
[ROM][WIP][AOKP] Android Open Kang Project Beta 26 for TF201[2/29/2012] - xda-developers
copied this from xda forums made by playfulGod i know some guys were looking for this.
]What is this?
This is the AOKP-android open kang project compiled for the TF201. I have tested this and this flashes with no problem. This rom has waaaaaaaay more features then CM9. Like seriously... it has a option in Settings called Rom Control. You can read about it here: AOKP | News
Disclaimer
I or PG are not responsible for what happens to your beautiful prime. So, please act with caution. I am 100% sure this works as I have tested it, however.... if if you dont know how to use adb, i suggest you stop reading right now and learn that first.
BEFORE YOU FLASH PLEASE READ
This rom has been shared for educational and entertainment purposes. Please dont flame, dont complain and please dont wine if you find something that doesn't work, this is why this is Work in Progress. Hopefully, it'll work 100% 1 day, and we of course have no ETA. So please do not ask. Maybe another dev can take a crack at it?
Who made this build? Compiled it?
This build was compiled by PlayfulGod. Please donate to him here: http://bit.ly/yeOD3T. Original work by AOKP. This is just a port for the tf201 and nothing more. Credit to AOKP. I have been given permission by PG to release it to the public. This rom comes with no support. However, you can stop by #asus-transformer on freenode and If i am around... I will gladly help. As the TF201 has been unlocked, i figured it would be beneficial to all android enthusiast to have more than 1 option for roms. That is why we are making this build available. Test it out and tell me what you think. Please expect bugs as this is a WIP. I will post screenshots soon.
What is not working?
Screen Rotation is only in Landscape mode (Looking into Orientation Switch on market)
Not all options in the Rom Control work
LED Options
Reboots when pressing the Power Button to sleep the TFP
Screen won't turn off while closing the dock/tablet
MicroSD (Looks like there is a solution for CM9, will look into it)
I have noticed on a few occasions as some of these options are not working with the TF201, it will do a fastboot. So, please do not complain.
Instructions
Install like any other rom, however MAKE SURE you unmount SYSTEM and unmount STAGING.
1. Make sure you're on the latest CWM
2. MAKE A NANDROID
3. unmount system & staging
3. wipe data/factory reset in recovery
4. flash ROM
5. flash Gapps (if you want)
6. reboot
Remember, to make a backup of your current rom. Also make a backup of your boot.img, so if you do decide to go back to your rom you can flash the boot.img and you'll be back to normal.
How to backup your Boot.img? You can use ADB or Terminal Emulator
1. su (to make sure you have #)(if your in adb.... adb shell)
2. dd if=/dev/block/mmcblk0 of=/sdcard/boot.img bs=4096 skip=3968 count=2048
Wanna restore to what you had?? Heres how to do it right....
So you saw it, you like it, you can't wait till it completely works, but you wanna go back to what you had for now....
1. Make sure you have your boot.img backed up from the rom your going to restore.
2. Go to CWM and do the Restore
3. Once thats done, go to ADB and flash Boot img
4. adb shell & su (make sure you have #)
5. dd if=/sdcard/boot.img of=/dev/block/mmcblk0 seek=3968 bs=4096 count=2048
6. Exit & Reboot
Now you should be back exactly where you are now be4 you flash AOKP.
Download
AOKP for TF201 - Build 26 - http://goo.gl/2LOiO
Gapps - Goo-inside.me Downloads - Browsing gapps-ics...224-signed.zip
]What is this?
Disclaimer
LED Options
Instructions
2. MAKE A NANDROID
4. flash ROM
6. reboot
6. Exit & Reboot
Download
