BobZhome
LG Optimus L9 (cm10.1(Android 4.2.2)) (MS769, MetroPCS)
Jellybean(Android 4.2.2)
Builder: BobZhome
Current Version: CM10.1.1-RC0-P769-BobZhome (7-26-2013)
Description: Well, let's be honest. Unless you're living under a rock, you probably know what Android 4.2.2 (Jellybean) is. Furthermore, you should know what the CyanogenMod project is. However, if a rock is really your home and you'd like to learn more, please visit their site: CyanogenMod
==== '''People worked with/owe thanks to:''' ====
==== '''What is not working?''' ====
==== '''Changelog''' ====
7-26-13:
==== '''Prerequisites''' ====
==== '''Flashing ROM''' ====
==== '''Download Links''' ====
Build 7/26: cm-10.1.1- RC0.p769.BobZhome.07262013.zip MD5checksum = 758d47dc829b26e47ecccec307fbab3e
Latest Gapps for CM10.1: gapps-jb-20130301-signed.zip
==== '''Q & A''' ====
Q: When will the next build come?
A: When time permits...I have a wife, five kids, full time job, and an old house that I'm remodeling...hobbies come last.
Q: Can I port your ROM?
A: No, please learn to build from source...my github link is in "Resources".
==== '''Resources''' ====
https://github.com/BobZmotion
==== '''How Can You Help?''' ====
Donations to me are also welcomed.
Thank You!
Builder: BobZhome
- CyanogenMOD - Do I need to state why we owe thanks to this guys?
- 1080p Video Recording - Which I removed the option for until fix
7-26-13:
- Sync'd with CM10.1(Android 4.2.2)
- Added: Ringtone - "Somebody's Out There" by one of my favorite bands: "Triumph"
- Added: Notification - "Heaven"
- Removed: Bootlooder option from Reboot/Recovery Menu
- Kernel: Added - Smartass2 Govenor
- Kernel: Added - InteractiveX Governor
- Kernel: Added - Simple IO Scheduler
- Kernel: Changed - GPU freq to 384MHz without changing the voltage
- Kernel: Added - CPU frequency 0.18, 1.2, 1.35, 1.38GHz
- Unlocked Bootloader
- Custom Recovery
- Boot into CWM Recovery
- IMPORTANT: Make a backup on sdcard : EXTERNAL SDcard
- Wipe Dalvik Cache: advanced > Wipe Dalvik Cache > Yes - Wipe Dalvik Cache
- Hit back button(bottom left) to get back to main menu
- Format Data: mounts and storage > format /data > Yes - Format
- Flash ROM: install zip from sdcard > choose zip from external sdcard > cm-10.1.1.P769.BobZhome > Yes - Install cm-10.1.1.P769
- Flash Gapps
- Reboot system now!
Thank You!
