Root [ROMlCOLOURSl]PORTED FOR A73
shahabazas
~*~ Android Addict ~*~
New Rom COLOURS by Mmrehman of XDA has been released and to make it work on our A73 we just need to flash the Latest Stock Baseband zip,BOOt and Logo zip and the camera zip as if the camera is foreclosing what is in the ROM so once flashing the zip of ROM just flash the zip files provided below and you will have everything working.
SOME FEATURES OF ROM COLORS
* Android 2.3.5 Pre Roooted
* Bravia Engine & Beats Audio
* FM Radio without headphones
* Inbuilt data2Ext support
Credits:
Mmrehman for porting it to Spice and to MEfor porting and testing it on A73 and providing the fixes
Disclaimer/Warning:
I AM NOT RESPONSIBLE FOR ANY HARM DONE TO YOUR PHONE USING THIS . DONT BLAME ME IF YOUR PHONE TURNS INTO A PAPERWEIGHT/BRICKED USING THIS. DO IT ON YOUR OWN RISK.
How to flash well its the same way you flashed the other ROMs still wanna know ok
Installation:
1. Download the zips from Download link
2. Dump it to SD card
3. Reboot to recovery
4. Factory reset
5. Wipe cache
6. Go to Advanced
7. Wipe Dalvik Cache
8. Wipe Battery stats
9. Go back
10.Select install zip from SD card.
11.Select the ROM zip
12.Select Yes
13.Follow instruction of Aroma installer
14.After the flashing complete go back
14.Flash all the other zips provided for all the fixes one by one
15. Reboot
16.........ENJOY.......
First boot takes about 3 minutes.After first reboot, Open file explorer and go to SDcard ,Here you find Scripts folder and 01data2ext file.
JUST MOVE THIS FILE(01data2ext) TO Scripts folder AND REBOOT ONCE AGAIN.Second boot also takes about 3 minutes.
NOW OPEN SYSTEM INFORMATION & SEE THE INTERNAL MEMORY.
NOTE:SIM background colour wont work as it is modified to display some icons on signal strength.As general rule BATTERY SHOULD BE
CALIBRATED EVERY TIME WHENEVER YOU FLASH NEW ROM.So calibrate your battery properly.
Here are the download links:
Boot and Logo
A73Boot&Logo.zip
A73LatestStockBaseband.zip
Camera Fix
2.3.5CameraFix
ROM Download
Dev-Host - COLORS.zip - The Ultimate Free File Hosting / File Sharing Service
Important
Once reboot please download this build prop extract it and paste/replace with the build prop in /system folder and give permission as r-w-rr
http://www.mediafire.com/?ft583ag8y10qybb
Original Thread for the ROM
http://forum.xda-developers.com/showthread.php?t=1880187
For any other problems if you face in future as if all the things are working with all the fixes what i have provided so if you get into any other problem then you can either post it over here or head over to the main ROM thread.
and hey dont forget to thanks Mmrehman on the main thread for porting it to spice.
ENJOY THE COLORFUL ROM
Screenshots:
I am downloading the files and would flash the ROM & return with my experience.
Previously I had flashed the ROM from [ROM]ANARCHY RELOADED by Mastermind, first custom rom for Micromax A73.
It was exciting,
It was android version 4.0.1.
Cons: Serious network issue.
What actually I am looking forward for:
Working Skype and Gtalk video chat, as A73 has front camera.
Till date not able to use them.
Ok I will come back...
For stable network on Anarchy you can just flash the file what i have provide...
MASTTTTT !!!!!!!!!!!!
Great performance, look, network ok, fully stable :), zero bug (till date) :p.
Its great man :shakehands:,
Thanks, I am satisfied.
WANT MORE: VIDEO CALLING GTALK, SKYPE.
Please suggest something :listen:
I Have Micromax A73 And I Have Installed Anarchy Rom Its Great
HEY Bro but Still There Is a problem, In Music Player
When I Try to set The Equalizer in Music Player The Music player get Restart
And Unable to Set Equalizer
COLORS works fine.. looks better...
But, I cant receive messages... tried message settings.. but in vain....
Can you please help..
ROM COLORS better than any other ROM available on internet..
No other problems !!!
