M Meh Well-Known Member Apr 17, 2012 #1 Hey all. I have now decided to get on and flash a custom ROM to my DS (prob CM7 first off
F FoX777 Well-Known Member Apr 17, 2012 #2 You are a little confused and advised you do some more reading. 1. don't even think about using an ota when your phone isn't stock. 2. RUU should bring you back to stock, may need to re do HTCdev though after. also must look at misc version and cid though. 3. use a custom recovery to install the roms. not fastboot. 4. after ROM flash use fastboot to flash the boot.img (you are confused about that.) 5. HTCdev provides adb and fastboot tools. 6. HTCdev may void warranty. 7. I would rather downgrade then soff.
