D
Deleted User
Guest
If I root my device, would I still recieve system updates?
yes. but you do not need to root to turn off auto updatesIf I root my device, would I still recieve system updates?
I want to de-bloat my phone. Currently, it has so many applications which I don't even use. Is there another way to de-bloat my phone other than root?yes. but you do not need to root to turn off auto updates
there is no development community behind your phone, unfortunately. so if the bootloader is unlocked then you can use a fastboot command to unlock the bootloader. once that is done then you can use magisk to give you root.I want to de-bloat my phone. Currently, it has so many applications which I don't even use. Is there another way to de-bloat my phone other than root?
Device: Oppo A12 CPH2083
OS: ColorOS 6.1.2 (Android 9)
Color OS is a fork of Android.
Excellent. I'm about to start working on something similar and I was worried there was going to be problems.yes. but you do not need to root to turn off auto updates
