K
KOLIO
Guest
Just received the LG G-PAD 7.0 LTE today.If you're familiar w/the G series of devices from LG,that's pretty much what you're getting,less a phone dialer.
Anyhoo,not much in the world of development for this device,not even a dedicated forum @ XDA.
However,a GOOGLE Search for Root for this device did turn up a post from a member @ XDA who used the PURPLE DRAKE (LITE) method which is/was used successfully on the LG G3.
Soooooo,long story short,it works.
If you want to root your LG G-PAD 7.0,go to YOU TUBE,search LG G3 Root with PURPLE DRAKE & select The UNLOCKR's how-to video.
All necessary links are provided & if you've already used LG's PC SUITE w/this device,then one step has been taken care of already (driver installation).
As far as a custom recovery,I suppose any available for the LG G3 may work,but,proceed at your own risk & w/o any ROMS available (AFAIK),no real need for such.
I'm good w/root only ATM,gonna check the XPOSED framework/modules for compatibility.
As there's not much activity in this forum,I thought it'd be best to post here,instead of the All Things Root section.
If interest/post count dictates,I'll request the discussion(s) be moved to the All Things Root section.
