Root Root gone wrong.
jellyark
Alright I was rooting my tablet, i forgot to check which version my tablet was so i rooted with the wrong root file..
When i boot up, i get passed everything to the main screen but the actual system is all messed up, i cant see a thing. My friend hard reset it threw the options you can get to threw holding power and down volume.
I was told i need to put the stock 3.1 file back on, problem with this is, my SD card on my tablet isn't formatted, so it's not showing up on my laptop as a storage device.
I can access both menus threw power + sound down, but other than that, that's all i can do atm.
search for information regarding Odin. You can flash the tock rom using that, your sd card does not need to be accessible via the PC.
