Root Root Help ICS 4.0.4
Hello,
I just got a Pink Samsung Galaxy Note and i want to root it? Which software is recommended to do this??
Phone Information:
Model: GT-N7000
Version: 4.0.4
Kernel: N7000XXLRK
Build: IMM76D.XXLRK
Hope you can help
Thank you
Are you sure you want to root it, what are you trying to achieve? Root will give you full administrative access to your file system, but will also stop certain apps such as Banking apps from working, as it's a security risk.
If you are just looking to install a custom ROM you can do this without rooting, just follow the procedure on Cyanogenmods website to install a custom recovery image....
Samsung Galaxy Note: Full Update Guide - CyanogenMod Wiki
I too am looking to root my phone, just so I can get rid of some bloatware. I do not want to install a ROM, just root. I've also read that installing CWM is a bad idea, is this true?
Model: GT-N7000
Version: 4.0.4
Kernel: N7000XXLRK
Build: IMM76D.XXLRK
I really don't understand why this is so difficult.
What I have
Samsung Galaxy Note N7000 fully charged.
ICS v 4.0.4
Baseband v XXLRK
Kernel 3.0.15-N7000XXLRK-CL811902
Build IMM76DXXLRK
What I want
Root N7000
4.2 update
Ubuntu
Problem I have
It would appear that I need to 'root' the phone, but I don't know how to do that. I keep reading how simple it is, but nothing is recognised by the Root Checker app I downloaded.
I see there is consensus here that Cyanogen is the way to go, but everywhere else I go, it states that the phone must be be rooted. So - if someone would be so kind - could you please explain how to root the N7000 in terms that we can actually understand?
Your help is greatly appreciated.
It would appear that I need to 'root' the phone, but I don't know how to do that. I keep reading how simple it is, but nothing is recognised by the Root Checker app I downloaded..
If all you really want is to start off by just being rooted, then read this thread first, and ensure you understand the terminology and the process before even starting to attempt to root, better to ask questions upfront before you flash, than after the event and you have semi-bricked phone :)
http://forum.xda-developers.com/showthread.php?t=1329360
