Thanks to eversleyd for finding this rooting method, please make time to thank him/her here.
Root LG Optimus L9 [Guide]
** This will root your phone and install an app called "superuser".
::What will the software do::
_______________________
1- Manages superuser (root) permission to apps.
2- Remove System Apps (At your own risk)
3- Increase Boot Speed by disabling apps that AutoStart (At your own risk)
4- Clean up tool for files and process.
5- Checks if Apps are up to date.
6-Using "GL to SD(root)" some apps could be moved to SD
This software is made by a Chinese company called mgyun.com and I don't know if their software should be trusted or if it's an open-source software (if anyone knows please share). If you have sensitive or classified information please do more research or ask your agency before installing it.
Downloading The Software:
The software is in Chinese and the app installed is in English.
you can download the software from the main site Here or from GoogleDrive Here
1-Make sure your phone is in Deubug Mode
System Settings-->Developer Options-->USB Debugging (not connected to usb cable yet, plug cable after selecting the option)
2-After downloading the software you would be asked to allow it to run. Click Run than Yes.
2-Keep Clicking Next until it asks you to lunch Root
3- Select Lunch and Click Finish
4- When the Program runs click on the root button.
Your phone should be rooted and the app installed in your phone.
Moving Some Apps To SD
Now one of the best tools to use with your rooted phone is this app that moves some of your apps from the phone memory to your sd card memory it is called GL to SD(root) by tnslf2k **this app can move some applications not all** as you know android 4.x is troubling with this.
Why Can't I Move All Apps to the External SD Card?
Android OS Allows transferring apps to Primary External Storage that is not emulated.
In the case of LG Optimus L9 the Primary External Storage IS emulated, and the sd card you place inside is consider Secondary External Storage.
Beside Moving Apps What Can I Do?
There is a new app that will switch the storage ID and therefor switch the storage device. the app is called
Root External 2 Internal SD
once you download it (& you're rooted) you will be able to switch them, make sure you change the camera setting to make the default storage the internal.
** Resetting the phone will not remove the software or root, to remove them you need to use the same Chinese software.***
