Got it rooted using TWRP with some advice from a member at XDA. Don't use custom roms myself, just stock using Apex Launcher and use App Master to uninstall all the bloatware bullshit.
Yes, if it isn't against forum rules I can post a link to the thread at xda.
I used ODIN to install TWRP then dropped that universal root zip on my Tab via USB then booted into TWRP and installed that root zip from there. Had an issue with SuperSU binaries, but got it sorted out and haven't had any issues at all.
I got the same when I tried to use the super su from the play store. I uninstalled the super su, then with twrp i flashed this version of super su:What do you mean by "got it sorted out". I'm having the issue with the binaries not installing properly, most likely due do KNOX. Any info would be appreciated.
Thanks.
Hi all
I have a Galaxy Tab 3 SM-T210 which has just had the official uk kitkat update, I am trying to get this rooted but can only find this forum mentioning the T217S sprint?
Does anyone know if there is a guide/files for rooting this model yet.
Cheers
