Hey guys I seem to be having a bit of a problem rooting my admire. I had my admire rooted and working fine with the 2.3.4 kernel, but could not send or receive mms. After a bunch of run-arounds with the metro customer service department getting me nowhere, I decided to look into this myself. I noticed a software update on the metropcs site and went ahead and updated. Turns out this was the update to 2.3.6 (duh), but I can send and receive MMS again, which is awesome.
My problem now is that I want to root it again but it doesn't seem to be going so well and I am thinking it is due to the new os version? Any help getting my phone back to rooted status would be great.
My output with one-click is as follows:
error: unknown host service
[*] Triggering core dump..."
[1] Segmentation fault app_process /dev...
cannot create /data/local.prop: permission denied
[*] Rebooting phone. It may buzz a lot and loop on boot. Don't panic."
remount failed: Operation not permitted
failed to copy 'su' to '/system/xbin/su': Read-only file system
Unable to chmod /system/xbin/su: No such file or directory
link failed Read-only file system
[*] Installing Superuser.apk. If this hangs, just cancel it with Ctrl+C after a
few seconds,"
[*] and you'll be finished rooting your phone. Reboot and enjoy."
1599 KB/s (196521 bytes in 0.120s)
Error: Could not access the Package Manager. Is the system running?
[*] Persistence complete, enjoy your rooted phone!"
Press any key to exit the script.
Press any key to continue . . .
few seconds,"
flash req0’s CWM and kernel first and wipe every thing
