There is no straight answer for what you are looking for.
Rooting your phone only grants you Root access. Think of it like a computer network. Root access is similar to having Admin rights on a network.
Getting root access will then allow you to load custom ROMs or Kernels that can help you with whatever you're trying to achieve.
It is simple, once you understand the process and learn what you need to do. Before you get to the part where its simple, you'll want to read up on the process. Flashing ROMs and kernels have the potential to brick your phone, so you need to be comfortable with it.
