Folks,
I know this is a bit of a hot item for some. How to root a Verizon Samsung Galaxy Note 3 running Lollipop. Well I did find a way that works. Here is the thread: http://forum.xda-developers.com/ver...b6-of1-n900v-note-3-verizon-oneclick-t3333569
The link for the rooting program is a bit scary www.droidyemen.com or www.androidyemen.com. The process was not 100% smooth and I had to try a few times to get it right. Apparently the speed of your computer can affect the success. Despite the failures there was no (apparent) damage to my rig. Closing the program, power cycling the phone, and trying again was all it ultimately took. Now I have root. I verified with a root check. I also enabled the hidden menu and can enter service codes now! TitaniumBackup works too. Wow, wow, and double wow. Been a long time coming.
The process is:
1) Download the zip file from the link. (I ran the file through Avast and SuperAntiSpyware and it was clean).
2) Then unpack it. (I ran the file through Avast and SuperAntiSpyware and it was clean).
3) Plug the phone into a USB2.0 connection.
4) Run the program.
5) Press "Read Phone Info" and wait for the fields to fill in.
6) Take a deep breath and press "ROOT".
-- When it works a progress bar will show up on the bottom half of the phone screen under the "don't power off warning". Also you will see a "ROOOOting" message.
-- If it is not working you will see a full row or more of dots show up on the program screen.
If more than 5 minutes have gone by with no progress bar or reboot of the phone, then close the program. Hold down the power button on the phone until the power cycles, and try again. If that does not work, then reboot the PC and try again.
NOTE: My 2nd time rooting the phone I "proved" that rebooting the PC yields a good rooting. Five or six tries without reboot = no success. Then PC reboot and poof first time.
When it works the phone will reboot. My phone rebooted quite sluggishly and I also ended up with a message about some item (sorry I did not take note of it) appears inactive, wait or continue. I chose "wait" a few times and that only ended up with another reboot at some point later. Ultimately power cycling the phone got me back to a normal boot.
NOTE: My 2nd time rooting the phone it rebooted just fine with no trouble.
By the way Knox is NOT tripped.
Now I REALLY hesitate to send $$ to a group called xxxxYEMEN fearing a call from Homeland Security or something.
Comments? Fears? Things I should check for because I was stupid to give this a try? Let me know.
NOTE:A few weeks running now with no issues. Still happy.
YMMV.
Ron <><
The process is:
4) Run the program.
YMMV.
Ron <><
