Root SPH-L700 Sprint Nexus
  • Start date Start date
A
Android Question
Guest
I would like the simplest root method for my Sprint Samsung galaxy nexus model sph-l700 . Is there any one click method or similar method to give me root with SuperSU and cwm ? I have found a few such as casual but it mentions I should be on android 4.04 but I am running a the stock 4.1.2 Jellybean . Can anyone point me to the most noob friendly way to do this ? thanks
If you're using Windows, using Wugs Nexus Toolkit will automate most of the procedure. Download and install the program. Once you run it for the first time, select your device and OS version. First you'll need to configure your adb and fastboot drivers. It will walk you through doing this. Next you'll have to unlock the bootloader if it's still locked. Once again it will do most of the work and walk you through doing any things you have to do yourself. Finally is root the device. Same thing, it will do a lot of the really techincal stuff and walk you through the manual stuff after that, reboot your device and you're rooted. :)
