Root ZTE Midnight?
  • Start date Start date
A
Android Question
Guest
So I have the ZTE Midnight (Z768G) and I am getting the classic "low on space" message and I know what rooting is as I rooted my Nook Tablet 4GB but I can't seem to find a root that will work for my phone so that I can set my default storage to the SD card and I was wondering if someone could help me. Or if there's alternatives to rooting it that would also be nice. I installed an app that can erase cache but it's not doing much for me right now. I can't even update my apps. Any help would be nice!!
OP, I see that you question was answered over on XDA, but that you are still having issues moving apps to sd. I don't know if you're aware, but you can't move system apps or apps that are specifically coded as non-movable. Also, apps2sd type utilities require that you partition your external sd card first.
An easier solution might be to use FolderMount. I use it myself, and it's excellent!
anyone know how to "SIM UNLOCK" this bad boy?
Welcome to the forum. I see that this is your first post, so perhaps you are unaware of protocol. It is considered poor form and "hijacking" to post off-topic questions to someone else's thread. The OP will appreciate it, and you will be doing yourself a favor, by creating your own thread (plus you'll be more likely to receive an answer).
