Hi
note usre if im posting this in the correct place but here goes....
first time rooter so i hope this makes sense
im having trouble opening rooted apps after rooting my galaxy s 2.3.3
e.g
undelete - sorry but your device isnt rooted
screenshot - something about privleges
i did everything as instructed (sorry cant post link)
my phone status even reads correctly as if its rooted which makes this more confusing (i checked this on youtube)
downloaded superuser from the market but i cant update due to
checking for busybox - not found
checking current install path - fail
failed to find currently installed su binary
dont know if this will helps but i downloaded terminal emulator - not really sure what this does to be honest but when i open it reads:
export PATH=/data/local/bin:$PATH
$export PATH=/data/local/bin:$PATH
im probly being silly and its something quite simple but i just cant seem to figure out the problem
hopefully someones had similar issues and managed to find a fix
any help would be greatly appreciate
thank you for you time
e.g
my phone status even reads correctly as if its rooted which makes this more confusing (i checked this on youtube)downloaded superuser from the market but i cant update due to
