Root Rooted M835
starxpilot
Well, thought I'd post this to get some feedback and see if I did right, or did wrong.
Rooting the phone seemed like a pain in the ass, did it with Super One Click, using the default pn...
After that, I couldn't get Titanium to work, so used Root Explorer. From there, after it got Superuser Permissions, I went ahead and started deleting Apps, such as stock ones from the folders within. Phone starts going faster and more memory has been freed.
Now I'm not sure if this is the best way to do it but it seemed to work how I did it, but its really hard to figure out what app is what, because if you delete the wrong file, you can brick your phone.
I used this video to help but since he didn't root it himself, its hard to see what its supposed to do.
‪How To Root Huawei M835‬‏ - YouTube
Hope this helps for others that are just getting the phone.
hey starxpilot do you have the stock mms settings I downloaded a ideos rom and I was wondering if you or anyone has the stock mms settings for a m835
What do you have Metro PCS?
APN: #777
Proxy: proxy.metropcs.net
Username: YourPhoneNumber@aaaj.mymetropcs.com
Password: metropcs (im not sure about this just guessing)
Port: 3128
MMSC: http://mms.metropcs.net:3128
MCC: 311
MNC:660
Authentication Type: PAP or CHAP
APN type: * [Update: I found out this should be 3]
That's what a grabbed from my phone, anything I left out was blank, good luck.
Hmm, I don't have the phone on me, it belongs to a co-worker. However, he's due to have me service it again since some .apks did NOT get removed correctly...
Or better yet, didn't get removed at ALL.
If I can grab the stock apks and settings for you I will, but looks like you'll have to grab what you can, see if Sebuo's method works.
The thing most annoying about the rooting process and general usage is the phone's so damn tiny, I have to make sure I read the words right...then again, makes it that much harder when you're in the root manager and see a bunch of numbers and digits and half of a name...
