Root rooted mt3g fender volume randomly raises, gets stuck
camronb04
Like the title says. I havea MT3g fender rooted with cyanogenmod version 5 loaded. More often than not my volume turns up and gets stuck. I have to battle with it until it stops. I have tried killing all apps when this occurs and it does not fix the problem.
I was wondering if there is something that could be typed into the dummy terminal to disable the volume rocker? If not is there another fix?
Thanks
