Wow. Tough spot. First I'd read up as much as I could on baseband updating (or downgrading). I believe there is a way to do that with a special tool, but you have to have the proper file obviously...
I'd Google: samsung intercept baseband firmware
There's a thread (see link) on the sdx forums for developers. Why not ask your question there? Research first!
Getting back to "True" Stock on VM Intercept?
You asked your question over there right?
Also, I think you have to look around, for example:
Virgin Mobile Froyo 2.2 StockROM, kernel, and other stuff. *Ok GO! Fixed!*
Another asking might put it over the threshold.
Also, there is a special tool for flashing a baseband. Possibly, you just need to find the baseband...
Do you know what the proper one is? How about the tool?
Over there, present a little more info on what you have done, and maybe you'll have success.
