Can you get to the bootloader and fastboot or recovery? You can flash a ROM with ADB Sideload or restore the factory images.i rooted my nexus 4 and accidently i wipe out all the things from my phone and now it wont factory reset and it doesnt show google logo and it doesnt turn on its completely blank and i dont have option to usb debug can anyone help?
yes i can get into bootloader and fastboot but i cannot factory resetCan you get to the bootloader and fastboot or recovery? You can flash a ROM with ADB Sideload or restore the factory images.
Not factory reset... restore factory images, a very different process which reformats the entire phone and returns it to out of box condition by flashing a complete software image to the phone. You can follow this procedure to manually (long way) do it: [HOW-TO] How to flash a factory image / retu… | Nexus 4 | XDA Forums, use a tool like Wugfresh toolkit, but the factory images have a file called flash-all.bat will do a full flash for you (assuming you have adb/fastboot setup correctly in your system path).yes i can get into bootloader and fastboot but i cannot factory reset
You don't need to... Start TWRP, go to Advanced, ADB Sideload, connect USB cable, it should connect. Then type 'adb devices' it should show a "SIDELOAD" device.i cannot go in usb debugging mode for installing drivers
It is usually informative for other users to state how you solved your problem.thanks for everthing
my problem is solved
